As of Indigo 6.1.8, we're now using the standard Python logging facility. We made this change in preparation for a complete overhaul of plugin logging in Indigo 7. This change has introduced some logging issues. Several plugins began logging odd things into the Indigo log. The reason is that libraries used by those plugins are set by default to log at the INFO level, and they contain logging at that level. We log everything at the INFO level to the Indigo log, so now there is more stuff showing up.
The primary library we're seeing is the requests library, and more specifically the urllib3 library that's installed with it. That library liberally uses INFO level logging throughout. We believe that pattern, for a library, is a poor design, but it is what it is. Fortunately, there's a simple way to fix it. Once you import the library, you can adjust the level thusly:
- Code: Select all
logging.getLogger("requests").setLevel(logging.WARNING)
logging.getLogger("urllib3").setLevel(logging.WARNING)
You can use it for either - the current crop of unneeded logging is specifically in the urllib3 library, so you can just adjust that. You can use any of the standard logging levels of course. Anything below that level will not be logged. The default for both is logging.INFO, but setting it to a higher level will solve the problem.
See this stackoverflow post for a more complete discussion.
