Python Requests Module
Mon Mar 14, 2016 9:08 pm
I've been spinning my wheels a bit on this, so I thought I'd reach out to folks smarter than me. I'm trying to access an API using requests.
Here is my (non)working code:
import requests
from requests.auth import HTTPDigestAuth
requests.packages.urllib3.disable_warnings()
s = requests.session()
r = s.get('https://SERVER_IP', auth=HTTPDigestAuth('USERNAME', 'PASSWORD'), cookies={"new-cookie-identifier": "1234abcd"}, verify=False)
print r.content
payload = {'data': 'dhcp_leases'}
r1 = s.get('https://SERVER_IP/api/edge/data.json', params=payload, verify=False)
print r1.status_code
print r1.content
The first get works, and returns content (the idea being that this call would provide the session cookie.) The second get is where the rubber meets the road. However, the session doesn't seem to stay active and I get:
{"success":false,"errors":["Permission denied"]}
I've tried many things, but none successful. I'm sure that it's something pretty simple, but I haven't been able to find workable examples to draw from. Hopefully, someone can point me in the right direction. :D
Dave
Tue Mar 15, 2016 4:11 pm
Re: Python Requests Module
I don't know about the cookies, but it seems like you need to include the cookie in the second get or you'll lose the session, right? It'll think the connection is a new one.
Tue Mar 15, 2016 5:23 pm
Both requests are using the same session object ('s'), so I don't think that's absolutely necessary. But the examples I was looking at were inconclusive. And while I use the requests library in some of my code, I don't use the session object and I don't have any that use another get after the authenticating one. Hmmm.
Tue Mar 15, 2016 7:13 pm
Jay, I'm pretty sure you're right. I misread the docs:
Note, however, that method-level parameters will not be persisted across requests, even if using a session. This example will only send the cookies with the first request, but not the second:
@FlyingDiver: Thanks. I think I'm close, and I think my problems now are formatting the second request properly.
Here's where I'm at presently:
import requests
s.auth = ('USERNAME', 'PASSWORD')
s.get('https://10.0.1.1', verify=False)
r = s.get('https://10.0.1.1/api/edge/data.json', params={'data': 'dhcp_leases'}, verify=False)
print r.status_code
print r.text
Result:
Fatal error: Cannot redeclare class [blah, blah, blah]
The '200' is encouraging, anyway...
