18:28:35
18:29:13 -in Line '8062' has error='UnexpectedNullError -- CClientMgr not created'
18:29:13 - pi2 RPI{u'ipNumberPiSendTo': u'192.168.1.22', u'sendToIndigoSecs': u'90.0', u'piNumberReceived': u'2', u'sensorList': u'Wire18B20*137345691,BLEconnect*65802248,i2cOPT3001*1497048646*68,i2cBMExx*1336842918*119*17,i2cTSL2561*864053974*57,', u'piOnOff': u'1', u'ipNumberPi': u'192.168.1.22', u'piUpToDate': [], u'piDevId': 25018397, u'deltaTime2': 0.3365211486816406, u'output': {u'display': {u'1514723531': [{u'i2cAddress': u'60'}, {u'devType': u'screen'}]}}, u'userIdPi': u'pi', u'rPiVersion': 0, u'deltaTime1': 0.08419489860534668, u'lastMessage': 1507591753.015342, u'enableRebootCheck': u'restartLoop,-', u'passwordPi': u'karl123.', u'input': {u'Wire18B20': {u'137345691': u''}, u'BLEconnect': {u'65802248': u'18:65:90:6A:B9:0D'}, u'i2cOPT3001': {u'1497048646': u''}, u'i2cBMExx': {u'1336842918': u''}, u'DHTxx': {u'1815353069': u''}, u'i2cTSL2561': {u'864053974': u''}}, u'enableiBeacons': u'1', u'sensorRefreshSecs': 20, u'deltaChangedSensor': 5, u'piMAC': u'00:1A:7D:DA:71:14'}
18:29:13 -in Line '9567' has error='UnexpectedNullError -- CClientMgr not created'
18:29:13 -warning, ignoring state update: in Line '11448' has error='UnexpectedNullError -- CClientMgr not created'
18:29:13 -in Line '756' has error='UnexpectedNullError'
18:29:13 - pi0 RPI{u'ipNumberPiSendTo': u'192.168.1.20', u'sendToIndigoSecs': u'90.0', u'piNumberReceived': u'0', u'sensorList': u'INPUTgpio-1*266587410,i2cBMExx*1491353324*118,BLEsensor*244991166,BLEconnect*65802248,BLEconnect*142616409,BLEconnect*462988504,i2cOPT3001*999157650*68,', u'piOnOff': u'1', u'ipNumberPi': u'192.168.1.20', u'piUpToDate': [], u'piDevId': 1477958849, u'deltaTime2': 0.7487449645996094, u'output': {u'setTEA5767': {u'1800415532': [{u'i2cAddress': u'96'}, {u'devType': u''}]}, u'OUTPUTgpio-1-ONoff': {u'1964742022': [{u'gpio': u'26', u'initialValue': u'up', u'outType': u'0'}]}, u'neopixel': {u'246403135': u''}, u'OUTPUTgpio-1': {u'1752078745': [{u'gpio': u'21', u'initialValue': u'up', u'outType': u'0'}]}, u'OUTPUTgpio-4': {u'567118407': [{u'gpio': u'21', u'initialValue': u'x', u'outType': u'0'}, {u'gpio': u'20', u'initialValue': u'x', u'outType': u'0'}, {u'gpio': u'16', u'initialValue': u'-', u'outType': u'0'}, {u'gpio': u'12', u'initialValue': u'x', u'outType': u'0'}]}, u'display': {u'146308284': [{u'i2cAddress': u'60'}, {u'devType': u'st7735'}], u'1160879538': u'', u'1040812751': [{u'i2cAddress': u'60'}, {u'devType': u'screen'}], u'748719371': [{u'i2cAddress': u'39'}, {u'devType': u'LCD1602'}]}}, u'userIdPi': u'pi', u'rPiVersion': 0, u'deltaTime1': 0.03413701057434082, u'lastMessage': 1507591753.855757, u'enableRebootCheck': u'restartLoop,-', u'passwordPi': u'karl123.', u'input': {u'INPUTgpio-1': {u'688656134': [{u'count': u'off', u'gpio': u'21', u'inpType': u'low'}], u'266587410': [{u'count': u'off', u'gpio': u'16', u'inpType': u'high'}]}, u'i2cBMExx': {u'1491353324': u''}, u'BLEsensor': {u'244991166': u''}, u'BLEconnect': {u'65802248': u'18:65:90:6A:B9:0D', u'142616409': u'FC:E9:98:49:BB:E9', u'462988504': u'AC:29:3A:EC:A9:9F'}, u'i2cOPT3001': {u'999157650': u''}}, u'enableiBeacons': u'1', u'sensorRefreshSecs': 20, u'deltaChangedSensor': 5, u'piMAC': u'5C:F3:70:6D:DA:7A'}
the code for fist error:
line 8062 is
dev = indigo.devices[self.RPI[unicode(pi)]["piDevId"]]
except Exception, e:
self.ML.myLog("all", u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
self.ML.myLog("all", u" pi" + unicode(pi)+" RPI"+ unicode(self.RPI[unicode(pi)]) )
# .logfile handling
import indigo
import os
import sys
import datetime
import time
class MLX():
def __init__(self):
self.logFile = ""
self.logFileActive = False
self.debugLevel = "all"
self.maxFileSize = 20000000
self.lastCheck = time.time()
####----------------- set paramete rs ---------
def myLogSet(self, **kwargs ):# eg (debugLevel = "abc",logFileActive=True/False ,logFile = "pathToLogFile", maxFileSize = 10000000)
for key, value in kwargs.iteritems():
if key == "logFileActive":
self.logFileActive = value
elif key == "logFile":
self.logFile = value
elif key == "debugLevel":
self.debugLevel = value
elif key == "maxFileSize" :
self.maxFileSize = int(value)
if len(unicode(e)) > 5:
indigo.server.log(u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
def myLog(self, msgLevel, text, type=""):
if msgLevel == "" and self.debugLevel != "all": return
if time.time() - self.lastCheck > 100:
self.checkLogFiles()
if not self.logFileActive:
if msgLevel == "smallErr":
indigo.server.log(u"------------------------------------------------------------------------------")
indigo.server.log(text)
return
if msgLevel == "bigErr":
indigo.server.log(u"==================================================================================")
return
if msgLevel == "all" or self.debugLevel.find("all") > -1 or self.debugLevel.find(msgLevel) >-1:
if type == "":
indigo.server.log(text, type=type)
return
return
else: # print to external logfile
if len(self.logFile) < 3: return # not properly defined
f = open(self.logFile,"a")
f.close()
except:
pass
return
ts = datetime.datetime.now().strftime("%H:%M:%S")
if type == u"":
f.write((ts+u" "+u" ".ljust(20) +u"-" + text + u"\n").encode("utf8"))
f.write((ts+" " +type.ljust(20) +u"-" + text + u"\n").encode("utf8"))
f.close()
return
f.write(u"----------------------------------------------------------------------------------\n")
f.write((ts+u" ".ljust(12)+u"-"+text+u"\n").encode("utf8"))
f.close()
return
f.write(u"==================================================================================\n")
f.write((ts+u" "+u" ".ljust(12)+u"-"+text+u"\n").encode("utf8"))
f.close()
return
return
try: f.close()
except: pass
Reloading plugin "piBeacon 7.67.153"
Stopping plugin "piBeacon 7.67.153" (pid 32520)
Script Error embedded script: HandlerError -- all request handlers are disabled
embedded script, line 9, at top level
StandardError: HandlerError -- all request handlers are disabled
Stopped plugin "piBeacon 7.67.153"
Starting plugin "piBeacon 7.67.153" (pid 32735)
f.close()
except:
pass
return
if type == u"":
f.close()
return
f.close()
return
f.close()
return
return
######## ------- here the loop starts --------------
while self.quitNow == "":
self.countLoop += 1
self.sleep(5.)
if self.countLoop > 5:
anyChange= self.periodCheck()
if self.statusChanged ==1: self.setGroupStatus()
if self.statusChanged ==2: self.setGroupStatus(init=True)
if self.enableFING == "1":
if self.updateFING("loop ") == "break": break
indigo.server.log( u"hello shutting down after While ...: loop ")
while True
except: pass
kw123 wrote:ok I am idiot ..
