[ANSWERED] Add Custom Device State Dynamically
Tue Feb 09, 2021 5:38 am
Re: Add Custom Device State Dynamically
matt (support) wrote:
... What you want to do is something like this:
   def getDeviceStateList(self, dev):
      stateList = indigo.PluginBase.getDeviceStateList(self, dev)
      if stateList is not None:
         # Add any dynamic states onto the device based on the node's characteristics.
         if dev-supports-something:
            someNumState = self.getDeviceStateDictForNumberType(u"someNumState", u"Some Level Label", u"Some Level Label")
            someStringState = self.getDeviceStateDictForStringType(u"someStringState", u"Some Level Label", u"Some Level Label")
            someOnOffBoolState = self.getDeviceStateDictForBoolOnOffType(u"someOnOffBoolState", u"Some Level Label", u"Some Level Label")
            someYesNoBoolState = self.getDeviceStateDictForBoolYesNoType(u"someYesNoBoolState", u"Some Level Label", u"Some Level Label")
            someOneZeroBoolState = self.getDeviceStateDictForBoolOneZeroType(u"someOneZeroBoolState", u"Some Level Label", u"Some Level Label")
            someTrueFalseBoolState = self.getDeviceStateDictForBoolTrueFalseType(u"someTrueFalseBoolState", u"Some Level Label", u"Some Level Label")
            stateList.append(someNumState)
            stateList.append(someStringState)
            stateList.append(someOnOffBoolState)
            stateList.append(someYesNoBoolState)
            stateList.append(someOneZeroBoolState)
            stateList.append(someTrueFalseBoolState)
      return stateList
With Indigo 7.5, I am looking fora self.getDeviceStateDictForFloatType but trying that doesn't seem to work?
Can it be added or is there another way to force this? :)
Tue Feb 09, 2021 3:54 pm
Re: [ANSWERED] Add Custom Device State Dynamically
Try getDeviceStateDictForRealType(). :twisted:
Tue Dec 28, 2021 6:06 pm
LSpad offline
Hi there,
Apologies for revisiting an old question. My use case is actually a fair bit simpler, as I’m not looking for different state lists by device, just a single list of states for all devices defined on startup.
Is it possible to define a dynamic list of states in the devices.xml? I’ve tried setting it out using the same construction as in the events.xml but I keep throwing an error that lists in devices.xml must have at least one state (even if I pre populate the dynamic list construction method with a tuple for unknown state). In my devices.xml I’m currently doing something like:
<State id="mode">
        <ValueType>
                <List class="self" filter="" method="myModeListGenerator"/>
        </ValueType>
</State>
Wed Dec 29, 2021 6:51 pm
Unfortunately, no. For the XML based <State> it is 100% static (no callbacks), so the only way to dynamically alter the list is to override the getDeviceStateList() method as described above.
Mon Jan 03, 2022 3:45 pm
LSpad offline
Many thanks for getting back Jay,
I'm struggling a little to crack this one! I have a plugin I'm developing which creates a bunch of AV renderers representing audio or visual products on a network. Each renderer has a unique set of sources that it can play, combining local sources that are unique to each renderer with shared distributed sources.
In my devices.xml I have created a state called source which is a string list:
<States>
         <State  id="source">
            <ValueType>
               <List>
                  <Option value="Unknown">Unknown</Option>
                  <Option value="Standby">Standby</Option>
               </List>
            </ValueType>
            <TriggerLabel>Source Changed</TriggerLabel>
            <TriggerLabelPrefix>Source is</TriggerLabelPrefix>
            <ControlPageLabel>Current Source</ControlPageLabel>
            <ControlPageLabelPrefix>Source is</ControlPageLabelPrefix>
</State>
When my plugin starts up it interrogates the central gateway for the network which provides an .xml config file containing details of all network nodes, including their available sources. I'm storing that data for each device and I'd like to be able to dynamically alter the state list for each device so that the state options only include the available sources to the device. I've overwritten
            if dev.deviceTypeId in self.devicesTypeDict and dev.deviceTypeId == u"AVrenderer":
                # Add dynamic states onto statelist for devices of type AV renderer
                sources = dev.ownerProps['sources']
                for sourceName in sources:
                    src = (u"source", sources[sourceName]['source'], sourceName)
                    stateList.append(src)
        return stateList
so I'm trying to append something like the following to that state list:
(u'source', u'A.TAPE/A.MEM', u'A.TAPE')
(u'source', u'CD', u'CD')
(u'source', u'PHONO/N.RADIO', u'PHONO')
(u'source', u'RADIO', u'RADIO')
(u'source', u'A.TAPE2/N.MUSIC', u'iTUNES')
This doesn't work and I can see I'm mangling the stateliest - how do I add the elements to the list correctly?
With best wishes
Luke
Mon Jan 03, 2022 7:17 pm
Looks like you're adding a tuple to the state list, not a dict.
Here's the code from the Ecobee plugin:
        device_type = dev.pluginProps.get("device_type", None)
        if device_type in ['athenaSmart', 'corSmart', 'apolloSmart', 'vulcanSmart']:
            stateList.append({  "Disabled"     : False,
                                "Key"          : "hvacMode",
                                "StateLabel"   : "HVAC Mode",
                                "TriggerLabel" : "HVAC Mode",
                                "Type"         : 150 })
                                "Key"          : "latestEventType",
                                "StateLabel"   : "Last Event",
                                "TriggerLabel" : "Last Event",
                                "Type"         : 150 })
                                "Key"          : "device_type",
                                "StateLabel"   : "Model",
                                "TriggerLabel" : "Model",
                                "Type"         : 150 })
                                "Key"          : "climate",
                                "StateLabel"   : "Climate",
                                "TriggerLabel" : "Climate",
                                "Type"         : 150 })
                                "Key"          : "equipmentStatus",
                                "StateLabel"   : "Status",
                                "TriggerLabel" : "Status",
                                "Type"         : 150 })
                                "Key"          : "occupied",
                                "StateLabel"   : "Occupied (yes or no)",
                                "TriggerLabel" : "Occupied",
                                "Type"         : 52 })
                                "Key"          : "autoAway",
                                "StateLabel"   : "Auto-Away (yes or no)",
                                "TriggerLabel" : "Auto-Away",
                                "Type"         : 52 })
                                "Key"          : "autoHome",
                                "StateLabel"   : "Auto-Home (yes or no)",
                                "TriggerLabel" : "Auto-Home",
                                "Type"         : 52 })
                                "Key"          : "fanMinOnTime",
                                "StateLabel"   : "Minimum fan time",
                                "TriggerLabel" : "Minimum fan time",
                                "Type"         : 100 })
        elif device_type in ['nikeSmart']:
                                "Key"          : "hvacMode",
                                "Type"         : 150 })
                                "Type"         : 150 })
                                "Type"         : 150 })
                                "Key"          : "climate",
                                "Type"         : 150 })
                                "Type"         : 150 })
                                "Key"          : "autoAway",
                                "Type"         : 52 })
                                "Key"          : "autoHome",
                                "Type"         : 52 })
                                "Type"         : 100 })
        elif device_type in ['idtSmart', 'siSmart']:
                                "Key"          : "hvacMode",
                                "Type"         : 150 })
                                "Type"         : 150 })
                                "Type"         : 150 })
                                "Key"          : "climate",
                                "Type"         : 150 })
                                "Type"         : 150 })
                                "Type"         : 100 })
        return stateList
Tue Jan 04, 2022 8:16 am
LSpad offline
Many thanks for this Joe,
That's really helpful - however, I'm not sure I understand correctly. What I'm trying to do is add a tuple to the existing list of possible states for 'source'. As far as I can tell, essentially those options are represented as statename.option in the stateList so If I try the following:
                # Add dynamic states onto stateList for devices of type AV renderer
                for source_name in sources:
                    # src = {u"source", sources[source_name]['source'], source_name}
                    stateList.append({"Disabled": False,
                                      "Key": "source." + source_name,
                                      "StateLabel": "Source is " + source_name,
                                      "TriggerLabel": "Source is " + source_name,
                                      "Type": 50})
        return stateList
It essentially produces the options I want in the triggers list, but I raise the error
Error (client)                  device "BeoMaster 7000" state key source.A.TAPE not defined
Perhaps I'm taking the wrong approach editing the stateList - I'm not trying to add a new state, but rather add a tuple to an existing the options for an existing state? Apologies for lots of silly questions but there is little documentation on this as far as I can see?
Tue Jan 04, 2022 9:18 am
When do you get that error? Do you have debug logging that shows what method you're in?
Are you calling
device.stateListOrDisplayStateIdChanged()
at an appropriate time? Such as in deviceStartComm()?
I've never tried modifying the state value list on the fly, so I'm not sure this actually works for your use case.
Tue Jan 04, 2022 2:57 pm
LSpad offline
Okay - cracked it!
The missing element was setting the StateKey (which I guessed by blind luck from the error message)
                        stateList.append(
                                "Disabled": False,
                                "StateKey": sources[source_name]['source'],
                                "Type": 50
                except KeyError:
                    indigo.server.log("Device " + dev.name + " does not have state key 'sources'\n")
        return stateList
    def deviceStartComm(self, dev):
        dev.stateListOrDisplayStateIdChanged()
