Comparing Device Objects [Solved]
Sat Mar 17, 2018 7:39 pm
I think I might be code-blind. I'm working with something based on subscribeToChanges() and trying to isolate on what's actually changed between origDev and newDev. In starting to work on a way to compare the two objects, I came across a result that I find perplexing.
dev1 = indigo.devices[1149686816]
dev2 = indigo.devices[1149686816]
indigo.server.log(str(dev1 == dev2))
Log:
Mar 17, 2018, 8:31:34 PM
   Script                          False
I would think they would be equal......but how to tell the difference between the two?
I started down a path of converting the device instances to Unicode and then parsing the string, but is there an easier way? What I want is only the changes:
# prop or state: (old, new)
brightness: (42, 100)
onState: (False, True)
Sat Mar 17, 2018 7:50 pm
Colorado4Wheeler offline
Re: Comparing Device Objects
if old.onState == new.onState:
How I check for changes is iterate through all the attributes and states. So for states:
for key, val in old.states.iteritems():
  if key in new.states and new.states[key] != old.states[key]:
Edit: I forgot to tack on .iteritems() to that iteration.
Sat Mar 17, 2018 8:31 pm
Log:
   Script                          False
They're not equal because your Python code is getting a copy of the actual device info on the server. Not a pointer to it. So each copy is distinct. And you're comparing the device object pointers, not the contents.
Sun Mar 18, 2018 5:41 am
Thanks. I should've been more clear (told you I was code blind)...
I realize I can compare them element by element, I was hoping there was a more straightforward way of doing the comparison. I don't know, like with a dictionary comprehension or something:
dev1 = {'k1': 'v1', 'k2': 'v2'}
dev2 = {'k1': 'v1', 'k2': 'v3'}
d = {k: (dev1[k], dev2[k]) for k in dev1.keys() if dev1[k] != dev2[k]}
indigo.server.log(str(d))
Result:
{'k2': ('v2', 'v3')}
But that won't work for device objects. How about indigo.listOfChanges(origDev, newDev)? :)
That's the bit I find perplexing. Why isn't it comparing the contents? If I compare two dictionaries with the same contents, they will come back as equal. In one case it's comparing the pointers and in the other case it's comparing the values.
Sun Mar 18, 2018 6:54 am
I believe that's because the dictionary data type implements the __cmp__ function which is designed to do a deep compare. The Indigo device data type does not.
Sun Mar 18, 2018 7:16 am
I see I need to do a bit more studying. :)
Sun Mar 18, 2018 7:23 am
https://docs.python.org/2/reference/dat ... ct.__cmp__
object.__cmp__(self, other)
Called by comparison operations if rich comparison (see above) is not defined. Should return a negative integer if self < other, zero if self == other, a positive integer if self > other. If no __cmp__(), __eq__() or __ne__() operation is defined, class instances are compared by object identity (“address”)
Sun Mar 18, 2018 7:29 am
Sun Mar 18, 2018 1:51 pm
We probably should implement (internally) the __cmp__ method for Indigo objects. But in the mean time I think what you want to do is this:
indigo.server.log(str(dev1.id == dev2.id))
As internally Indigo forces all objects to have a unique ID which is not mutable (and doesn't change as python instances of the objects are created).
Sun Mar 18, 2018 2:10 pm
Thanks Matt -- I'm looking to compare the 'origDev' and 'newDev' objects that are sent to def deviceUpdated(self, origDev, newDev) for changes. I'm looking to identify what about the device has changed without iterating through all the props and states. Maybe that's the only way to do it...
Sun Mar 18, 2018 4:56 pm
Ah yes, my suggestion won't help with that at all. I think even if we implemented the __cmp__ method that wouldn't help with what you are after though, since you want a list of exactly what has changed. Here is roughly how the SQL Logger plugin handles it:
changeDict = { key:val for key, val in newDev.states.iteritems() if key not in origDev.states or val != origDev.states[key] }
Although I don't believe that handles the case of a state being deleted (it does handle them being added). That is pretty much an edge case though, as in general plugins should never delete a state since it will potentially break Triggers, Conditionals, etc., that reference it.
Mon Mar 19, 2018 6:03 am
Thanks Matt. This works great for device states, but I was also looking for a way to detect changes to device props. But after a few tests, it doesn't look like deviceUpdated() is called when a device's props change. Does that sound right?
Mon Mar 19, 2018 6:25 am
deviceUpdated() is called when the properties (or anything else: name, states, etc.) change. I'm not sure why it isn't in your case/example, but definitely is routinely (we have plugins that rely on it).
Mon Mar 19, 2018 7:17 am
All I can come up with is this error:
   Script Error                    embedded script: developer is too stupid to live
   Script Error                    Exception Traceback (most recent call shown last):
     embedded script, line 123, at top level
PEBKACError: developer is too stupid to live
It is, of course, called. So I guess my question is this: Is there an iterator I can call to grab all the device's props for inspection? I haven't been able to land on one that seems to work. May also be a result of the above error.
If I need to call the props from an internal list, I can do that, too.
Mon Mar 19, 2018 8:59 am
You missed a critical 'Except' in that trap....
Except:
  "He writes good plugins that a lot of people use and that makes up for anything he thinks are dumb mistakes"
:lol:
