Update device state in 'while loop'
Wed Apr 03, 2024 9:10 am
CliveS offline
I am trying to break out of a while loop when a contact sensor changes but the script obviously only knows the state at the start. Is there a way of updating it inside the loop?
# Import the time module for time-related functions
import time
# Initialize the loop counter
count_loop = 0
# Get the device by its ID
dev = indigo.devices[683155862]  # "Z Aqara P1 door & window contact"
# Log the current state of the onOffState
indigo.server.log(f"Current onOffState: {dev.states['onOffState']}")
# Pause execution for 2 seconds
time.sleep(2)
# Retrieve the initial state of the onOffState
doorStatus = dev.states["onOffState"]
# Loop until the doorStatus becomes True or count_loop reaches 10
while not doorStatus and count_loop < 10:
    # Log the current iteration number and the onOffState
    indigo.server.log(f"Loop iteration {count_loop}, onOffState: {doorStatus}")
    # Increment the loop counter
    count_loop += 1
    time.sleep(2)
    # Update the doorStatus with the current state
# Log a message indicating the end of the loop and the final value of count_loop
indigo.server.log(f"Loop finished, count_loop is {count_loop}")
CliveS
Wed Apr 03, 2024 11:10 am
Re: Update device state in 'while loop'
You have to re-fetch the dev object inside the loop, then compare the current state to the saved state.
Wed Apr 03, 2024 11:42 am
CliveS offline
Joe, can you give a pointer to the way of doing that in the Indigo documentation please.
CliveS
Wed Apr 03, 2024 11:46 am
You're fetching a copy of the device object when you do "dev = indigo.devices[683155862]", which is the only Indigo specific thing here.
count_loop = 0
startDoorStatus = dev.states["onOffState"]
indigo.server.log(f"Current onOffState:  {startDoorStatus}")
# Loop until the doorStatus changes or count_loop reaches 10
while count_loop < 10:
    time.sleep(2)
    indigo.server.log(f"Loop iteration {count_loop}, onOffState: { dev.states["onOffState"]}")
    # Check the doorStatus
    if startDoorStatus != dev.states["onOffState"]:
       break
    count_loop += 1
Wed Apr 03, 2024 12:14 pm
CliveS offline
That works a treat, I see what I was doing wrong now and another one for my 'python howto file'
Thank you very much.
CliveS
Wed Apr 03, 2024 1:26 pm
A slightly more efficient way to update the device instance is with this API (compared to fetching an entirely new instance from the server):
dev.refreshFromServer()
Wed Apr 03, 2024 2:40 pm
CliveS offline
Thanks Matt, I will try that as well, a good learning curve, and another line in the ‘python howto file’.
CliveS
Wed Apr 03, 2024 2:49 pm
I should have remembered that one.
Sat Apr 06, 2024 2:29 am
kw123 online
Q: how does this work? Does indigo remember the last fetch? And then gets the new data only?
Sun Apr 07, 2024 2:13 pm
It fetches all the current device states and properties, replacing those attributes in the instance. I don't recall what happens if the device class changes (say from a dimmer to a thermostat), so no promises that will be handled correctly or gracefully.
Wed Apr 17, 2024 9:30 am
kw123 online
Added this code to the beginning of runConcurrentThread(self) ( before the main loop) in one of my plugins to check what the effect of dev.refreshFromServer() vs dev = indigo.devices{} ds:
      devId = 1667343748
      tStart = time.time()
      for ii in range(1000):
         dev = indigo.devices[devId]
         dev.updateStateOnServer("hardwareVendor",str(time.time())) # dummy state update of an empty unused state
      indigo.server.log( "after 1000 iterations with new dev=indigo.devices[] dt = {:.5f} ".format(time.time() - tStart))
      self.sleep(1)
         dev.updateStateOnServer("hardwareVendor",str(time.time()))# dummy state update of an empty unused state
      indigo.server.log( "after 1000 iterations with dev.refreshFromServer(): dt = {:.5f} ".format(time.time() - tStart))
i got:
after 1000 iterations with new dev=indigo.devices[] dt = 0.79437
after 1000 iterations with dev.refreshFromServer(): dt = 0.89304
dev.refreshFromServer() seems to be a tiny bit slower than dev = indigo.devices[devId] ... or am I looking at some caching effect?
and on a side note:
      indigo.server.log( "dev.updateStateOnServer after 1000 iterations  = {:.5f} ".format(time.time() - tStart))
gives:
dev.updateStateOnServer after 1000 iterations dt = 0.00636
Wed Apr 17, 2024 10:45 am
You're only measuring the time spent in the plugin, not the load on the server.
Wed Apr 17, 2024 11:43 am
kw123 online
ok got that,
2. test with a larger loop (1k--> 20k) to check the cpu time manually w activity monitor
      devId = 1667343748
      indigo.server.log( "starting w 1 20000 loop , check server load")
      self.sleep(2)
      for ii in range(20000):
      indigo.server.log( "after 20000 iterations with new indigo.devices[] dt = {:.5f} ".format(time.time() - tStart))
      time.sleep(50)  ## let the cpu indicator cool down
      indigo.server.log( "starting w 2. 20000 loop , check server load")
      self.sleep(2)
      indigo.server.log( "after 20000 iterations with new refreshFromServer dt = {:.5f} ".format(time.time() - tStart))
gives
after 20000 iterations with new indigo.devices[] dt = 16.17746
after 20000 iterations with new refreshFromServer dt = 16.31658
in both cases CPU load:
indigo 2023.2 up to 120%
indigo server 50%
the plugin is around 1-4%
it looks as if in both cases the execution takes ~ 16 secs for 20,000 iterations and the CPU load is about the same ( kind of in overload @ 120% for indigo client, should not be the dev.updateStateOnServer as that alone w/o the dev =indigodevcies[] is done in 0.1 secs)
next step would be to measure the total cpu consumed ( within the plugin ) before and after loop for indigo client and server processes
Wed Apr 17, 2024 2:22 pm
kw123 online
Using the same loops as before , just adding a call to
/bin/ps -ef | grep 'Contents/MacOS/Indigo 2023.2' | grep -v grep"
and
/bin/ps -ef | grep 'IndigoServer' | grep -v grep
that returns something like:
...... 29:53.49 Applications/Indigo', '2023.2.app/Contents/MacOS/Indigo', '2023.2']
...... 30:11.51 Applications/Indigo', '2023.2.app/Contents/MacOS/Indigo', '2023.2']
and the delta 30:11.51 - 29:53.49 should be the consumed CPU time
gives:
            indigo.devices[]  vs     refreshFromServer
indigo client:   18.02         vs      21.54 secs
indigo server:    6.87         vs      10.59 secs
loop with
indigo.devices[]    --> ~24 secs consumed CPU by indigo server and indigo client
refreshFromServer   --> ~31 secs consumed CPU by indigo server and indigo client
in Summary
if this is correct the loop with 20,000 calls
w dev=indigo.devices[] uses 7 secs LESS CPU that the loop with dev.refreshFromServer()
Thu Apr 18, 2024 11:08 am
Hi Karl,
Interesting performance numbers. I would have expected the opposite. I just looked at the python API / glue code and I would expect that dev.refreshFromServer would be the same speed or a bit faster than requesting a new device instance from the server.. I agree with your data though, so there must be some overhead I'm not seeing. I'd probably still recommend using dev.refreshFromServer on the chance that some day we add some optimizations to it (and it isn't horribly slower), but that is just a personal preference.
