Load Plug-in
Posted:
Mon Jan 08, 2024 5:24 pm
by SMUSEBY
What is the python script for loading a plug-in?
Re: Load Plug-in
Posted:
Mon Jan 08, 2024 6:13 pm
by DaveL17
There is no script for loading a plugin. This is for security reasons. You can only restart a plugin once it's already running.
- Code: Select all
plugin = indigo.server.getPlugin("com.indigodomo.somePlugin")
plugin.restart(waitUntilDone=True)
The
waitUntilDone argument is optional.
Re: Load Plug-in
Posted:
Mon Jan 08, 2024 7:20 pm
by FlyingDiver
And you don't need a script if all you want to do is restart a plugin. It's available as an action under "Server Actions".
Re: Load Plug-in
Posted:
Mon Jan 08, 2024 7:48 pm
by SMUSEBY
I was putting it in front of a script with an MQTT command that was failing.
It was the latest of many 'guess-and-check' failed solutions to MQTT implementation.
But it doesn't work.
