Convert Python 2.5 Scripts to 3?
Wed Nov 08, 2023 1:14 pm
ckeyes888 offline
Getting an error running these scripts in 2022.2
Guessing they need to be updated to Python 3?
#! /usr/bin/env python2.5
# -*- coding: utf-8 -*-
import simplejson
import urllib2
DTVIP = "192.168.1.53"
url = "http://%s:8080/tv/getTuned?" % DTVIP
f = urllib2.urlopen(url)
simplejson_string = f.read()
f.close()
parsed_simplejson = simplejson.loads(simplejson_string)
   programTitle = parsed_simplejson['title']
   indigo.variable.updateValue(1708209973, programTitle)
except:
   indigo.variable.updateValue(1708209973, " ")
   majorCh = str(parsed_simplejson['major'])
   indigo.variable.updateValue(564695813, majorCh)
except:
   indigo.variable.updateValue(564695813, " ")
theText ="Ch " + indigo.variables["DTVchannelNumber"].value + " - " +  indigo.variables["DTVprogramTitle"].value
indigo.variable.updateValue("DTVall", theText)
indigo.variable.updateValue("Message_Upper", theText)
Appreciate any help!
Carl
Wed Nov 08, 2023 2:51 pm
CraigM offline
Re: Convert Python 2.5 Scripts to 3?
I would be curious to see how accurate this online converter did.
import simplejson
import urllib.request, urllib.error, urllib.parse
f = urllib.request.urlopen(url)
f.close()
except:
except:
Wed Nov 08, 2023 3:41 pm
ckeyes888 offline
Still no go:
Script Error embedded script error:
Script Error No module named 'simplejson'
embedded script, line 4, at top level
ModuleNotFoundError: No module named 'simplejson'
Carl
Wed Nov 08, 2023 4:15 pm
pip3 install simplejson
Wed Nov 08, 2023 4:50 pm
Change:
import simplejson
to:
import json as simplejson
That should fix it (I don't believe the ancient simplejson module works in python3 since python 2.7 and newer included json).
Honestly, the better (but slightly more pervasive change) would be to just substitute json for simplejson throughout the script.
Wed Nov 08, 2023 5:10 pm
Let's use this script as a learning opportunity since you posted the entire script. Here's how I would update it:
import requests  # Indigo includes this and it's easier to use for making HTTP requests
# Constants - change as needed for your specific environment
PROGRAM_TITLE_VAR_ID = 1708209973
MAJOR_CHANNEL_VAR_ID = 564695813
# The rest shouldn't need to change unless you want to add more values to new variables
url = f"http://{DTVIP}:8080/tv/getTuned?"
# Get the JSON message from the device
reply = requests.get(url)
# Get a python dictionary from the JSON in the reply
reply_dict = reply.json()
# Set your Indigo variable values
   programTitle = reply_dict['title']
   indigo.variable.updateValue(PROGRAM_TITLE_VAR_ID, programTitle)
except:
   indigo.variable.updateValue(PROGRAM_TITLE_VAR_ID, " ")
   majorCh = str(reply_dict['major'])
   indigo.variable.updateValue(MAJOR_CHANNEL_VAR_ID, majorCh)
except:
   indigo.variable.updateValue(MAJOR_CHANNEL_VAR_ID, " ")
Untested, but it should be close.
Wed Nov 08, 2023 7:17 pm
ckeyes888 offline
Works great.
Overall the upgrade from 7.2 to 2022.2 has gone amazingly well!
Many thanks!
Carl
