Python to Find/Replace Text
Sun Jan 15, 2023 10:12 am
ckeyes888 offline
I'm attempting to switch from Fantastic Weather to the NOAA plugin but am having issues with all the possible weather conditions
and corresponding icons I use.
Hoping I can revise my script to find certain words in a variable and set my icon variable accordingly.
e,g, precip, mist to simply mist.
Here's the script I've been trying.
theText = indigo.variables[175134881].value
if "Clear" in theText:
    indigo.variable.updateValue(175134881, value="Sunny")
elif "Cloudy" in theText and "Mostly" in theText:
    indigo.variable.updateValue(175134881, value="Cloudy_Mostly")
Carl
Sun Jan 15, 2023 12:13 pm
Re: Python to Find/Replace Text
And what does or doesn't work when you use that script?
One thing I would do is change the first line to:
theText = indigo.variables[175134881].value.lower()
Then you can test with lower case strings and it'll work no matter that case they are in the variable.
Sun Jan 15, 2023 12:45 pm
ckeyes888 offline
Thanks for the tip on upper and lower case.
The problem is NOAA comes up with dozens of descriptions for conditions.
For example I’d just like the script to convert something like ”partially clear” to just “clear.”.
Or, “likely light snow”, to “snow”.
Carl
Sun Jan 15, 2023 1:12 pm
That script should work then, if you're just looking for specific keywords.
Sun Jan 15, 2023 1:17 pm
ckeyes888 offline
I assume it’s not working because of the case issue which I’ll fix later and see if that’s it.
Carl
Sun Jan 15, 2023 2:39 pm
ckeyes888 offline
Still no go. If it returns "light rain" it doesn't change to "Rain".
elif "Rain" in theText and "Light" in theText:
    indigo.variable.updateValue(175134881, value="Rain")
Carl
Sun Jan 15, 2023 2:42 pm
You really need to show your current code and the input text if you expect help.
Sun Jan 15, 2023 4:02 pm
ckeyes888 offline
Sorry if it was confusing.
For now just trying to get this to work:
if "Overcast" in theText:
    indigo.variable.updateValue(175134881, value="Overcast")
elif "Rain" in theText:
So if the variable became "mostly overcast" it would set it to "overcast".
thanks,
Carl
Sun Jan 15, 2023 4:34 pm
Your input text is now all lower case, so you need to change the if statements to match.
Sun Jan 15, 2023 4:40 pm
ckeyes888 offline
Is there a way to make it ignore upper/lowercase?
The states are all over the place. Just got one “Unknown, misty, rain”.
Carl
Sun Jan 15, 2023 4:49 pm
What I said to do does that. Just use "rain" not "Rain" in your script.
Sun Jan 15, 2023 10:17 pm
ckeyes888 offline
Tried a number of variations, upper and lower case, but none work.
if "fog" in theText:
    indigo.variable.updateValue(175134881, value="Fog")
If the variable contains, "patchy fog" it doesn't convert it to "Fog".
Carl
Sun Jan 15, 2023 10:32 pm
You're doing something wrong. That script worked exactly right for me. The only thing I changed was the variable ID.
Mon Jan 16, 2023 8:50 am
ckeyes888 offline
Doh, was using a condition that no longer worked.
Works great, thanks for the help.
Carl
