transferred indigo to new mac and python scripts
Fri Jan 06, 2023 4:34 pm
wamartei offline
hi,
i transferred indigo to new mac and can no longer run python scripts. The user is the same and the file path is the same, but the python scripts won't run through indigo. new mac is on ventura
thanks
Fri Jan 06, 2023 4:53 pm
Re: transferred indigo to new mac and python scripts
Did you follow all the steps in the Moving Indigo to another Mac section of the docs? And you're running Indigo 2022.1.x?
Fri Jan 06, 2023 8:03 pm
wamartei offline
I used migration assistant, which appears to have copied over application support folder. i installed latest indigo on top of that. Everything appears to be working except for python scripts
Sat Jan 07, 2023 4:36 pm
What errors are you seeing in the Event Log? And how are you running your scripts?
Sun Jan 08, 2023 3:25 pm
wamartei offline
there's no error message in the event log. i'm using indigo action "run shell script" "/Users/xxxxxxx/Sites/stIndigo/wsgi-scripts/hdmiTCPIP.py "living 3 1""
this has worked for at least a couple of years on the old 2013 mac pro (not running ventura)
when i transferred to this ventura/mac studio, i had an issue with plex media server which i was able to solve by enabling "full disk access". i've tried that with indigo server located in "/Library/application support/perceptive auto/indigo 2022.1" but to no avail
when i run the script in the python IDE, it works fine. when i use "open file" in indigo action on the same file, the file opens, so it seems indigo can access the file or at least locate it...
thanks
Sun Jan 08, 2023 5:07 pm
The shebang (!#) on the first line of your script is probably pointing to the wrong python (Apple stopped including Python in OS releases after macOS 12.3, so we started including our own). Assuming your script needs python 2, you'll want it to be:
#! /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
If your script needs python 3, then use this shebang:
#! /Library/Frameworks/Python.framework/Versions/3.10/bin/python3
Sun Jan 08, 2023 8:36 pm
wamartei offline
Yes, that worked, thanks!
