pip install indigo fails
Thu Jan 05, 2023 11:30 am
Different Computers offline
I'm unclear under which version of indigo I should be installing the indigo module.
    clang -Wno-unused-result -Wsign-compare -Wunreachable-code -fno-common -dynamic -DNDEBUG -g -fwrapv -O3 -Wall -arch arm64 -arch x86_64 -g -I/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/numpy/core/include -I/Library/Frameworks/Python.framework/Versions/3.10/include/python3.10 -c indigo/backends/_customcpu.c -o build/temp.macosx-10.9-universal2-3.10/indigo/backends/_customcpu.o -std=c11 -fopenmp -m64 -O3 -Wno-unknown-pragmas
      clang: error: unsupported option '-fopenmp'
      error: command '/usr/bin/clang' failed with exit code 1
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> indigo
What am I doing wrong? I've tried:
pip install indigo
python3 -m pip install indigo
py -3 -m pip install indigo
CC=gcc python -m pip install indigo
All fail for one reason or another on my Monterey M1 Mini. Xcode is installed.
Last edited by Different Computers on Thu Jan 05, 2023 11:35 am, edited 1 time in total.
Thu Jan 05, 2023 11:34 am
Re: pip install indigo fails
Oh and the script I'm creating needs "sys" too and seems to have the same problems.
Getting ahead of myself, but this is what I'm trying to make happen:
import indigo
import sys
trackInfo = sys.argv[1]
trackName, artistName = trackInfo.split("|")
indigo.variable.updateValue(trackVariableId, value=trackName)
indigo.variable.updateValue(artistVariableId, value=artistName)
There's an AppleScript that populates the variables.
Thu Jan 05, 2023 11:44 am
You can't install the indigo module. It's included in the Indigo install. You do need to "import indigo" in the code, and you need to be running the script from Indigo.
Thu Jan 05, 2023 11:45 am
And the "sys" module is pre-installed for all versions of Python. You can't install it separately.
Thu Jan 05, 2023 12:44 pm
Guess I might be stuck then.
The idea was for AppleScript to pass variables to python, which would then pass them to Indigo.
Thanks anyway! Think I might have another way to do it.
Thu Jan 05, 2023 3:43 pm
Check out the AppleScript integration strategies page for options.
