script help - "multiply by non-int of type 'float' error"
Tue Nov 22, 2022 11:19 pm
dtich offline
the below formula is throwing a multiply by non-int error that i can't quite sort out, any help with the syntax or other issue is appreciated! thx
the commented out lines are ref of the original formulas i'm trying to implement. i tried breaking them into summing variables in an effort to help with the multiply by error. i'm pretty sure i'm not handing the indigo variables properly, just can't figure it out... :D
Script Error schedule "weather update every 15min" embedded script error:
Script Error can't multiply sequence by non-int of type 'float'
embedded script, line 76, at top level
TypeError: can't multiply sequence by non-int of type 'float'
if cnthumid == "- data unavailable -":
   vardew = wthrStation.states['dewPointC']
   vartemp = wthrStation.states['temperatureC']
   import math
   argdew = math.exp((17.625 * vardew)/(243.04 + vardew)). --- THIS IS LINE 76
   argtem = math.exp((17.625 * vartemp)/(243.04 + vartemp))
   cnthumid = round(100 * (argdew / argtem), 2)
   #cnthumid = 100 * {math.exp[17.625 * wthrStation.states['dewPointC']/(243.04 + wthrStation.states['dewPointC'])] / math.exp[17.625 * wthrStation.states['temperatureC']/(243.04 + wthrStation.states['temperatureC'])]}
   #ref RH = 100 × {exp[17.625 × Dp/(243.04 + Dp)]/exp[17.625 × T/(243.04 + T)]}.
   indigo.variable.updateValue(1163325337, "alt")
   indigo.variable.updateValue(1163325337, "")
Wed Nov 23, 2022 12:20 am
Re: script help - "multiply by non-int of type 'float' error
Does that line actually have a period (decimal point) at the end? I don’t think that should be there.
Wed Nov 23, 2022 12:26 am
dtich offline
it doesn't, no. must've hit it while adding the comment. it's not in the code.
thx
Wed Nov 23, 2022 12:30 am
dtich offline
i'm realizing it is possible that this error could be thrown if the value of DewpointC is 'unavailable' or similar.. a text str that the station is reporting for whatever reason.. that could scuttle the whole formula. i haven't trapped for all those possibilities... not sure, but.. could be the case.
Wed Nov 23, 2022 10:32 am
ryanbuckner offline
Have you checked the type as a debug method:
print(type(vardew))
print(type(vartemp))
Thu Nov 24, 2022 1:17 pm
dtich offline
thanks ryan.
when i use test strs that are the expected values it works perfectly. i think this must be that the station is reporting another string i haven't seen/caught yet. i guess i'll just keep an eye out.
i have set the states to log when the alt computation method is used (when 'data unavailable' is returned from station the algorithm switches to the raw data and uses the involved dewpoint computation method to derive the rh - this is in fact how the station itself does it... when it works :D )
anyway, thanks for the thought. i think i'm gonna let this throw an error every now an again because i can't seem to keep up with the station's odd reporting at times. either way the system works through the error so it's ok.
Thu Nov 24, 2022 1:40 pm
dtich offline
also i have converted the dew and temp var from float to round and that may solve the other part of this. for some reason the math doesn't want to multiply a number by a float var... rounding it may fix? we'll see.
thx all
