Time difference
Wed Oct 19, 2022 3:11 am
MarcoGT offline
Time difference
Hi all,
I am trying to write a script to check if "now" is between sunrise and sunset, but I have problem to calculate the time difference (or maybe the time difference is not needed at all, it would be just enough to check with a IF and < >), anyway.
import datetime
sunrise = indigo.server.calculateSunrise()
sunset = indigo.server.calculateSunset()
now = datetime.datetime.now()
huePlugin = indigo.server.getPlugin("com.nathansheldon.indigoplugin.HueLights")
timeDelta1 = now - sunrise # if < 0, is bright enough
timeDelta2 = now - sunset # # if > 0, it is bright enough
indigo.server.log("timeDelta1" + timeDelta1)
indigo.server.log("timeDelta2: " + timeDelta2.strftime("%H:%M:%S"))
scala1 = indigo.devices[7081105]
scala4 = indigo.devices[1015827393] # "Scala-4"
isNight = indigo.variables[1390212289]
logMsg = ""
indigo.server.log("isNight: " + isNight.value)
# from here it is to be modified and use some variables, not yet implemented
# if ((isDark and scala1.brightness == 0) or (isNight == "true" and scala1.brightness == 0)):
if (isNight == "true" and scala1.brightness == 0):
    indigo.server.log("Motion KG: Is Dark or night is ON and Scala-1 is OFF, I will switch lights ON")
    huePlugin.executeAction("setCT", deviceId=7081105, props={"brightness":10, "temperature":2000})
    huePlugin.executeAction("setCT", deviceId= 1015827393, props={"brightness":10, "temperature":2000})
    time.sleep(45)
    huePlugin.executeAction("setBrightness", deviceId=7081105, props={"brightness":0, "rate":10})
    huePlugin.executeAction("setBrightness", deviceId= 1015827393, props={"brightness":0, "rate":10})
    indigo.server.log("45 seconds elapsed, I will switch off lights now")
   logMsg = "Motion KG: None of the conditions are satisfied, I will not switch the lights ON"
indigo.server.log(logMsg)
I am trying to print those line to check the values:
But I get:
Script Error                    trigger "Movimento Notte KG (Python)" script error in file Motion-KG.py:
   Script Error                    can only concatenate str (not "datetime.timedelta") to str
     Motion-KG.py, line 13, at top level
TypeError: can only concatenate str (not "datetime.timedelta") to str
Marco
Wed Oct 19, 2022 5:34 am
Re: Time difference
The error is due to the fact that you can't add a string together with a timedelta object. So instead of using a construction like this:
You need to make the two elements share the same type. Since you're logging, you need to make them both strings:
# In Python 3:
indigo.server.log(f"timeDelta1 {timeDelta1})
# In Python 2:
indigo.server.log(u"timeDelta1  {0}").format(timeDelta1)
You have more than one of those that you'll need to fix.
Wed Oct 19, 2022 5:44 am
Re: Time difference
Is there a reason you can't use the "isDaylight" variable?
Wed Oct 19, 2022 6:33 am
MarcoGT offline
Re: Time difference
Of course no reason, I totally forgot about that.
I will do it using isDaylight.
Thu Oct 20, 2022 11:06 am
MarcoGT offline
Re: Time difference
I do not understand why this statement is not working
if (isDaylight == False or isNight == True):
now both of them are false, it should enter in the "if"
Thu Oct 20, 2022 12:20 pm
Re: Time difference
Indigo variables are strings, not booleans. So you need:
if (isDaylight == "false" or isNight == "true"):
Probably. isDaylight will always be lower case. I don't know how isNight is getting set, so it might not be lower case.
Thu Oct 20, 2022 12:22 pm
Re: Time difference
Also, make sure you're getting the VALUE of the Indigo variable, not the variable object.
