Indigo server path INSIDE a file path or URL?
Mon Sep 05, 2022 12:12 pm
Different Computers offline
Hi all,
I have a ton of scripts with lines like this
original = Image.open("/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/public/alert.jpg")
or control page images located at (for example)
file:///Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/public/frontporch.jpg
and every time there's an indigo update, I have to manually change these file locations. I know there's a function (wrong term?) that gives the correct, current Indigo folder path, but I wonder if it's possible to include it as part of these file paths.
I think in the first case it might just be turning the target of Image.open into a declared variable, but I also don't know the syntax to do something like
targetImage="/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/public/alert.jpg"
original = Image.open(targetImage)
or if I'm even on the right track there. I'm not even clear what terms I would search for to look up how to do this in a python how-to. And that approach for sure won't work when I try to specify a control page file location, as far as I know.
Thanks much for any help!
Mon Sep 05, 2022 1:06 pm
Re: Indigo server path INSIDE a file path or URL?
Yes, the server function you want is indigo.server.getInstallFolderPath, and use it in your script like this (assumes Indigo 2022.1 or later):
 original = Image.open(f"{indigo.server.getInstallFolderPath()}/Web Assets/public/alert.jpg")
I'm less clear on your control page images: where are you using those file URLs?
Mon Sep 05, 2022 1:51 pm
If you're using this URL
as a Refreshing Image URL (for example), you can not use an Indigo method as a part of the URL.
If you're not taking advantage of using dropdowns to locate images (like with variables or devices) it may be best to put those images in a location outside the Indigo folder tree. That way the URL won't break when you update Indigo versions.
Mon Sep 05, 2022 3:37 pm
Dropdowns?
Mon Sep 05, 2022 3:41 pm
Those file urls are images that are on a web page, and they're refreshing URLs. Since I feel like I'm just repeating myself and probably don't understand what you're asking, here's a screen shot of a control page.
Screen Shot 2022-09-05 at 5.39.46 PM.png (31.55 KiB) Viewed 1377 times
Mon Sep 05, 2022 5:14 pm
Help me understand the use-case here: do you regenerate those images based on some change? What exactly changes that would cause you to edit them?
I'm wondering why using device states or image value heuristics with static custom images wouldn't work.
Also, given the file path, it looks like you are making that image available through the Indigo Web Server. So, instead of referring to it as a file URL, you can access it through IWS instead:
http://localhost:8176/public/alert.jpg
Mon Sep 05, 2022 5:33 pm
By dropdowns, I mean where you select Display Device State and then select a Device and a State (or a variable value or a static image). Most importantly As Image.
Screen Shot 2022-09-05 at 6.29.17 PM.png (30.29 KiB) Viewed 1358 times
The options listed in those dropdowns are stored in:
.../Web Assets/images/controls/devices/
.../Web Assets/images/controls/static/
.../Web Assets/images/controls/variables/
Images in these folders show up in Indigo's UI. Otherwise, I feel it's better to store images outside the folder tree so those "Refreshing Image URL" links stay the same between Indigo versions.
Tue Sep 06, 2022 7:45 am
Yes, based on motion alerts from cameras. Camect notices motion, takes a pic, saves those pics into web assests/public, tells domopad to display the page with that pic. I need to edit them because when a new Indigo version comes out, the path changes.
To clarify further: the "alert.jpg" is a camera snapshot that is created based on a camera motion trigger.
I don't have any idea what you have in mind here. The device state of the camera (alert) is the trigger. The image saves when the alert happens. So it's not a static image, and in any case the path to static images changes with each version of Indigo, doesn't it? Please explain how you imagine this would work because if I'm doing it the hard way, I want to know :) Maybe you're thinking I just want a big "sticker" that says "ALERT"? What I want is the snapshot from Camect OF the alert.
Now this I may be able to use immediately. No wait--see, the problem is that URL would then try to direct to the localhost of each client, wouldn't it? I think I'd need http://[IPADDRESS:8176/public/alert.jpg but that would break if I was away from home.
Last edited by Different Computers on Tue Sep 06, 2022 7:51 am, edited 1 time in total.
Tue Sep 06, 2022 7:49 am
Ah those. yeah, those are entirely unlike what I'm trying to display.
this is probably where I'm going wrong. But /web assets/public is also where Camect puts the images by default--which I don't think is a design flaw for camect. But maybe I should investigate changing that.
Tue Sep 06, 2022 9:54 am
Then use your reflector instead - that'll work from anywhere.
Tue Sep 06, 2022 11:11 am
I guess I'm still in the habit of avoiding anything that might route outside my network, which I think reflector connections do. Have I got that right?
this dates back to my sad old days of having ~8Mb down ~1Mb upload DSL but... now thanks to the electrical co-op, I have symmetrical gigabit fiber :D
Tue Sep 06, 2022 1:04 pm
So, the only other option you have is to put the image outside the Indigo install folder hierarchy so that the file URL never has to change.
Tue Sep 06, 2022 5:29 pm
I think the combination of my big internet upgrade (now a year old) and Camect’s default behavior point me to your other idea. But thanks!
