How do I get access back to my module?
Mon Jun 20, 2022 10:51 am
wikner offline
I have a bunch of sprinkler-controlling code which I placed in a module called "sprinklers"
A typical action will have an embedded python script such as the following:
import sprinklers
sprinklers.current_status()
My module used to (and actually still does, so its not lost) live at:
/Library/Python/2.7/site-packages/sprinklers.py
Where should I put this module so that Indigo 2202.1 can read it?
P.S. After all these years, I am still too lazy to learn how to make a plugin for my sprinklers.
Mon Jun 20, 2022 11:47 am
Re: How do I get access back to my module?
/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
Mon Jun 20, 2022 11:49 am
My suspicion is:
/Library/Application Support/Perceptive Automation/Python2-includes/
Or …../Python3-includes/
Ah, Joe beat me to it.
Also, you might need to make changes to support Python3, since your script will be running under that version.
Mon Jun 20, 2022 11:50 am
howartp wrote:
My suspicion is:
The latter might also work. But it's not obviously in the search path:
>>> import sys
>>> sys.path
'/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/InteractiveShell.indigoPlugin/Contents/Server Plugin',
'/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/InteractiveShell.indigoPlugin/Contents/Packages',
'/Applications/PyCharm.app/Contents/debug-eggs/pydevd-pycharm.egg', '
/Applications/PyCharm.app/Contents/debug-eggs/pycharm-debug.egg',
'/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns',
'/Library/Application Support/Perceptive Automation/Python3-includes',
 '/Library/Frameworks/Python.framework/Versions/3.10/lib/python310.zip',
'/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10',
 '/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload',
'/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages']
Mon Jun 20, 2022 11:52 am
Oops. It is. I missed it the first look.
That's the best place.
Mon Jun 20, 2022 12:01 pm
Correct. If you're still using Python 2:
Though that will only work until the next Indigo release.
Wed Jun 22, 2022 10:53 am
wikner offline
Thanks, everyone. I'll work on upgrading to Python 3 then put it in /Library/Application Support/Perceptive Automation/Python3-includes.
