Boolean logic question
Wed Jun 15, 2022 4:09 pm
SMUSEBY offline
I want the script to test the condition of two devices: if both aren't on, turn them on; else, turn them off.
Testing just one device with
if not (dev2.brightness > 10 ):
, it works, turning the devices on and off; when I test both devices, with
# if not (dev1.onState and \
#    not dev2.brightness > 10 ):
, it never gets to the 'else' condition . What am I missing?
# Device to be tested
dev1 = indigo.devices[35744300] # 1 k telLamp
dev2 = indigo.devices[1543856096] # 1 k whaleLamp
#test device condition
import time
time.sleep(1) #test device condition
# if both lamps are not on, turn them both on
 indigo.actionGroup.execute(885970154) # k Lamps AG ON
else:  # if both devices are on, turn them off
 indigo.actionGroup.execute(4135325) # k Lamps AG OFF
Wed Jun 15, 2022 4:15 pm
Re: Boolean logic question
Your parenthesis are nested wrong. Put it all on one line and look again.
Thu Jun 16, 2022 10:24 am
Untested, but either of these would be my approach:
if (not (dev1.onState) and dev2.brightness <= 10 ):
else:  # if ANY device is on, turn them BOTH off
or
if (dev1.onState == False and dev2.brightness <= 10 ):
I presume dev2 doesn't have an onState?
Having said that i'm not sure I can see why your current code doesn't work.
Fri Jun 17, 2022 5:51 pm
SMUSEBY offline
It didn't work because it lacked a set of parentheses. This works:
if not (dev1.onState) and \
   (not dev2.onState ):
But it isn't very neat.
I think your suggestion
if (dev1.onState == False and dev2.onState == False ):
is very nice. (I was using brightness under the mistaken assumption that there wasn't an onState for the z-wave device. There is.
