Do I need to change this script?
Sat May 28, 2022 9:22 am
jalves offline
I've got a couple of devices that I control via an embedded script. The script is triggered by a change in humidity level and it turns on a bathroom exhaust fan if the humidity in the bathroom gets significantly higher than the rest of the house. I do this so that the fan will automatically turn on when somebody showers. With that background, and help from Matt/Jay a few years ago, I've got the following script.
# Get the two humidity values
bathHumidity = indigo.devices[288098054].sensorValue  # ID of bathroom humidity device
bedroomHumidity = indigo.devices[1185510746].sensorValue  # ID of bedroom humidity device
# Calculate the difference and check to see if it's greater than or equal to 20
if (bathHumidity - bedroomHumidity) >= 20:
   # Difference is greater than or equal to 20, so turn on the device(s) for 10 minutes
   indigo.device.turnOn(404137540, duration=600)  # ID of exhaust fan
   indigo.device.turnOn(116176458, duration=600) #ID of toilet fan
The script seems to be functioning correctly with Indigo 2022.1.1 but I wanted to check if it will still function when Python 2.7 goes away.
Jeff
Sat May 28, 2022 9:43 am
Re: Do I need to change this script?
If it's running in 2022.1.1 then it's already using Python3 and nothing will change when 2.7 goes away.
Sat May 28, 2022 2:26 pm
jalves offline
Good to know Joe. Appreciate the response and your many Indigo plugins!
Jeff
