- Code: Select all
testscript.py: No module named pandas
ImportError: No module named pandas
How can I make pandas accessible for Indigo?
zaiks wrote:I know that, but as I can't get to access with python 2.7 due to [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727) error,
MightyBook:lib jay$ ls -la /System/Library/Frameworks/Python.framework/Versions/2.7/bin
total 0
drwxr-xr-x 26 root wheel 832 Jan 22 01:42 .
drwxr-xr-x 11 root wheel 352 Jan 22 01:42 ..
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 2to3 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 2to3-2 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 2to3-2.7 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 2to32.7 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 idle -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 idle2 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 idle2.7 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 pydoc -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 pydoc2 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 pydoc2.7 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 python -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 python-config -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 python2 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 python2-config -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 python2.7 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 python2.7-config -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 pythonw -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 pythonw2 -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 pythonw2.7 -> pythonwrapper
lrwxr-xr-x 1 root wheel 113 Jan 22 01:42 pythonwrapper -> /System/Library/Frameworks/Python.framework/Versions/2.7/Resources/pythonwrapper.app/Contents/MacOS/pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 smtpd.py -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 smtpd2.7.py -> pythonwrapper
lrwxr-xr-x 1 root wheel 13 Jan 22 01:42 smtpd2.py -> pythonwrapper
drwxr-xr-x 24 root wheel 768 Jan 22 01:42 unwrapped
MightyBook:lib jay$ python
WARNING: Python 2.7 is not recommended.
This version is included in macOS for compatibility with legacy software.
Future versions of macOS will not include Python 2.7.
Instead, it is recommended that you transition to using 'python3' from within Terminal.
Python 2.7.18 (default, Jan 4 2022, 17:47:56)
[GCC Apple LLVM 13.0.0 (clang-1300.0.29.10) [+internal-os, ptrauth-isa=deployme on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> ^D
