How to do a cURL call from Python
Mon Jan 03, 2022 6:02 pm
dstrickler offline
I'm a seasoned Indigo user, but a Python semi-newbie. Python seems "different" on the Mac (I'm used to Linux), so I'm asking for a specific command, but I bet general advice would help.
In linux I can say
curl --digest -u admin:{my_password} -X PUT -H "X-CSRF: x" --data "value=false" "http://10.0.2.14/restapi/relay/outlets/3/state/"
.. and the server at 10.0.2.14 comes back fine. However, when I do this from the Mac (10.0.2.12) that Indigo runs on (MacOX 12.0.1), the server at 10.0.2.14 times out with an internal error - it's not a TCP type error. I suspect it's something funky on the Mac, so I thought I would try and write a python script to simulate the cURL call.
Anyone have some pointers in how I would write the Python code? I know how to pass in data, but I don't know about the credentials digest, etc, and I want to do it the "indigo way".
Dave
Mon Jan 03, 2022 6:22 pm
Re: How to do a cURL call from Python
Python is pretty much the same everywhere. Your issue is likely that you need to specify a full path to curl.
I'd recommend using the requests library (which we include with Indigo) directly in Python rather than calling out to curl.
Mon Jan 03, 2022 7:03 pm
dstrickler offline
Thanks for the quick response Jay!
Perhaps my Mac (a standard install) is running an old version of Python? I know the 2.x versions are "retiring".
dstrickler@Indigo-Foxtrot-Mac-Mini indigo % python
WARNING: Python 2.7 is not recommended.
This version is included in macOS for compatibility with legacy software.
Future versions of macOS will not include Python 2.7.
Instead, it is recommended that you transition to using 'python3' from within Terminal.
Python 2.7.18 (default, Oct  2 2021, 04:20:39)
[GCC Apple LLVM 13.0.0 (clang-1300.0.29.1) [+internal-os, ptrauth-isa=deploymen on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import requests
  File "<stdin>", line 1, in <module>
ImportError: No module named requests
>>> quit()
Or with Python3 ...
  dstrickler@Indigo-Foxtrot-Mac-Mini indigo % /usr/bin/python3
Python 3.8.9 (default, Jul 19 2021, 09:37:32)
[Clang 13.0.0 (clang-1300.0.27.3)] on darwin
>>> import requests
ModuleNotFoundError: No module named 'requests'
>>> quit()
Dave
Mon Jan 03, 2022 8:08 pm
Requests is included with Indigo, but not with Python. You're going to have to import it from within an Indigo shell (or embedded script or linked script) or else you're going to need to install it yourself. If what you're doing is related to your Indigo setup--which it appears to be--I'd recommend running a linked script. Linked scripts aren't subject to the 10-second time limit that Indigo enforces on embedded scripts (linked scripts run in their own thread).
And I completely agree with Jay's recommendation to use Requests over curl whenever possible.
Tue Jan 04, 2022 9:22 am
dstrickler offline
Ah, so this matches what I see. If I use Python on the CLI, it doesn't have Requests. I need to run this from _within_ Indigo.
Thanks for the tip!
Dave
Tue Jan 04, 2022 9:42 am
Glad to help. Good luck!
Wed Jan 05, 2022 8:12 am
dstrickler offline
If anyone needs the basic code, here it is. This runs from within Indigo, but as @daveL17 points out, it's smarter to make an external script and have Indigo run the script for timeout reasons. If you don't, Indigo will pause doing anything else while you're script runs - normally not a good idea.
This calls the API's url and logs out the results, assuming they are in JSON format (most APIs use that these days).
import requests
import json
indigo.server.log("Making the API call...")
url = "https://you_domain.com/you_api/your_function"
resultObj = requests.get(url)
indigo.server.log("API call finished. resultObj:")
indigo.server.log(resultObj.text)
Dave
