Python neophyte - command computer to "sleep"
Thu Aug 19, 2021 11:17 am
KSimmons offline
Running Indigo 7.4.1 under Catalina in a rather warm hangar in Florida. I previously used AppleScript to put the computer to sleep when the outside temp variable went above 85°. Now that AppleScript is no longer supported, what is the Python script that I use to perform this same function. (I have the computer wake itself up later that evening when temps have cooled, using the "Wake on LAN" function)
I could not find an answer searching the Forum. I'm very new to Pythin.
– Kevin
Thu Aug 19, 2021 11:23 am
Re: Python neophyte - command computer to "sleep"
You can still issue AppleScript commands, you just can’t control Indigo with AppleScript.
Thu Aug 19, 2021 11:56 am
KSimmons offline
Thanks for the quick reply.
I was getting the error because I had the AppleScript embedded in the Actions tab as an "Execute Script". Rather than create a separate AppleScript and run it as a File, I wanted to try my hand at doing the same using Python.
Any suggestions for this as a Python command?
– Kevin
Thu Aug 19, 2021 12:42 pm
What was your AppleScript to do it?
Thu Aug 19, 2021 12:49 pm
KSimmons offline
This what I had as the AppleScript:
tell application "Finder"
sleep
end tell
Pretty simple. I would think this would be easy to translate over to Python.
– Kevin
Thu Aug 19, 2021 12:53 pm
sleep
end tell
– Kevin
Only by calling AppleScript from Python to do the "tell Finder" thing.
This should work:
import os
os.system("pmset sleepnow")
Thu Aug 19, 2021 1:08 pm
KSimmons offline
import os
Aha! I did see a reference to "pmset sleepnow" when searching for Python commands for "sleep". I did not know how to implement it correctly within Indigo however.
I will give this a try. Thank you!
– Kevin
