Python Error Help
Sat Jun 05, 2021 1:13 pm
ckeyes888 offline
Python Error Help
Hey,
Can’t get this to compile:
DTOD = indigo.variables[202906811] #DisplayTimeOfDay
DB = indigo.variables[1934444056] #display_bac
if DTOD == "morning" and DB == "Summer"
   indigo.variable.updateValue(1934444056, value="summer_morning") #display_bac
  elif DTOD == "afternoon" and DB == "Summer"
   indigo.variable.updateValue(1934444056, value="summer_afternoon") #display_bac
  elif DTOD == "evening" and DB == "Summer"
   indigo.variable.updateValue(1934444056, value="summer_evening") #display_bac
  elif DTOD == "night" and DB == "Summer"
   indigo.variable.updateValue(1934444056, value="summer_night") #display_bac
“invalid syntax”
Any idea why?
Carl
Sat Jun 05, 2021 2:22 pm
Re: Python Error Help
Because the indentation of the 'if' and 'elif' lines doesn't match. The 'elif' should be indented the same as the 'if' (in this case, not at all).
Sat Jun 05, 2021 2:30 pm
Also, you need colons at the end of the conditional (if, elif) lines.
Sat Jun 05, 2021 2:49 pm
ckeyes888 offline
Bingo on the missing colon.
Works great, thanks!
Carl
Sat Jun 05, 2021 2:50 pm
Spending a few hours doing an on-line intro to Python course would get you past these simple errors on your own...
Sun Jun 06, 2021 4:17 pm
Hey Carl, I don't think the script is working since you're comparing a variable instance against a string (rather than the value of the variable instance). I think you're looking for this, which I've cleaned up to make somewhat simpler:
if DB.value == "Summer":
   if DTOD.value == "morning":
   elif DTOD.value == "afternoon":
   elif DTOD.value == "evening":
   elif DTOD.value == "night":
Also note that you are updating the variable that you're initially checking for "Summer" - so after this script runs it may no longer be "Summer". Not sure if that's your intent or not.
And, I know we've recommended this before, but +1 to @FlyingDiver's recommendation to take an online python tutorial. It will really help you out.
Sun Jun 06, 2021 8:53 pm
ckeyes888 offline
Thanks Jay. Yes, I realized the mistake and corrected.
Also yes, I’m pretty hopeless at scripting. Always trying but I’m a graphics guy,..always struggled with any type of coding.
Carl
