Python 3 in Embedded Script
Sun Apr 18, 2021 9:03 am
ryanbuckner offline
Is there a way to use Python 3 using embedded script or file ?
I've tried this without success in Indigo. It runs on my local machine and runs on PyCharm on the server
#!/usr/bin/env python3.8
from shapely.geometry import Point, Polygon
coords = [
(39.008234937234256, -77.37684452531161),
(39.00809324520176, -77.37627518191934),
(39.00733602026089, -77.37671994280922),
(39.0076547326009, -77.37724949835487)
homeFence = Polygon(coords)
lat = 39.00777
long = -77.37668600000001
bmw = Point(lat, long)
if bmw.within(homeFence):
    #update indigo variable with True
    print(True)
    print(False)
Sun Apr 18, 2021 9:41 am
Re: Python 3 in Embedded Script
Not as such. But you can use Python 2.7 to run a script in a subprocess that calls Python 3x.
This Stack Overflow post has an answer that shows how to do this. You can get your True/False with the STDOUT pipe (you'd RETURN the bool instead of PRINT it).
Sun Apr 18, 2021 9:44 am
Hmm. Try running it as a shell script instead of an embedded python script. If you tell it to put the output in a variable, you should be able to use that variable in other logic.
Sun Apr 18, 2021 10:20 am
ryanbuckner offline
Ok, I think I get the gist. A little more help and I'll be there. I think I'm missing how to return the value back to the main process from the subprocess. p.stout = <_io.FileIO name=3 mode='rb' closefd=True> when I print it.
1) I have the embedded script which does this:
import sys
import indigo
from subprocess import Popen, PIPE
p = Popen(['python3', 'bmwgeo.py'], stdout=PIPE, bufsize=0)
print(p.stdout)
indigo.variable.updateValue(339870612,value=p.stdout)
2) then I have a file called bmwgeo.py in my Python2-Includes directory on the server that does this:
def isPointInside():
    coords = [
    lat = 39.00777
    return bmw.within(homeFence) #returns True or False
isPointInside()
Sun Apr 18, 2021 10:44 am
ryanbuckner offline
Ok Im going to go this direction. RETURN is not outputting the results from the python file. How do I return the value from the python script to the shell ?
Sun Apr 18, 2021 10:54 am
I think it's standard out, so
print("{}".format(bmw.within(homeFence)), file = sys.stdout)
Sun Apr 18, 2021 11:13 am
ryanbuckner offline
appreciate all your help on this. The .py file works properly and prints True / False to standard out.
Does the Indigo Shell receive this stdout when running the .sh file? Below is my file and Indigo throws an error. When I run the BMWgeo.sh file from terminal is returns True
#!/bin/sh
python3 bmwgeo.py
Event Log
Apr 18, 2021 at 1:01:35 PM
   Action Group                    Geofence BMW
   Action Collection Error         Run Shell Script action: script /Library/Application Support/Perceptive Automation/Python2-includes/bmwgeo.sh exited abnormally with a return code of: 2
Sun Apr 18, 2021 11:18 am
Run the bmwgeo.py directly, no shell script. You shouldn't need the shell script, if the shebang line is correct, and the python file has executable permissions.
Sun Apr 18, 2021 11:25 am
ryanbuckner offline
SUCCESS!!! I was over complicating it of course. You're the best.
Sun Apr 18, 2021 12:01 pm
Great!
I learned something here, too. Didn't realize that Indigo could run an external script in Python 3x directly. I'm so used to working through plugins that I was overcomplicating it too.
Sun Apr 18, 2021 7:22 pm
I thought it might be helpful to add a full example in case the discussion above wasn't clear. Create the Python 3 script file and save it to a location that Indigo has access to. Here's an example script that will fail in Python 2.7 but will work in this context.
foo.py
#! /usr/bin/env python3
# -*- coding: utf-8 -*-
some_list = [1, 2, 3]
first, *rest = some_list
print(rest)
In Indigo,
- run foo.py as a "Run Shell Script" action.
- if desired, store the result in an Indigo variable (the value sent by the 'print' command above will be redirected as output to the variable.) The above example will set the designated variable value to "[2, 3]".
Mon Apr 19, 2021 6:57 am
ryanbuckner offline
foo.py
print(rest)
In Indigo,
One more thing I had to do that wasn’t obvious. The directions using shell paths in Indigo say to use backslash as escape characters for spaces. This errored in the Indigo interface. Using quotes around the path worked.
Mon Apr 19, 2021 7:30 am
+1
Excellent point.
Wed Apr 21, 2021 4:01 pm
ryanbuckner offline
One thing I haven't figured out how to do is access Indigo through the Python3 script.
My best workaround is to have Python2.7 script save a variable value to a file, then have the Python3 script pick it up and use it.
I wasn't able to import indigo using [sudo] pip3 import indigo ... can I do it manually?
Wed Apr 21, 2021 4:14 pm
No, you can't do anything like that. On my plugins where I have a Python3 sub-process, I pass configuration data as command line arguments.
Unfortunately, it does not appear that you can include arguments with the Indigo action. So you might need to use a small embedded Python script to kick off the Python 3 script.
Something like:
Popen(["/usr/bin/python3", '/path/to/py3script.py', 'Arg1','Arg2'])
Then add this to the start of your Python3 script:
import sys
arg1 = sys.arvg[1]
arg2 = sys.argv[2]
