Python arithmatec
Tue Nov 10, 2020 3:17 pm
SMUSEBY offline
Python arithmatec
I am trying to update variable C with the difference between Var A and Var B, as follows:
varA = int(dev.states["temperature"])
varB = indigo.variables[1086851778].getValue(int)
varC = indigo.variables[515949397].getValue(int)
indigo.variable.updateValue(varC, varA - varB)
My syntax is not working.
Suggestions?
Tue Nov 10, 2020 3:27 pm
Re: Python arithmatec
Your call to updateValue needs the first argument to be an instance of an Indigo variable but you are passing an integer value. Try this:
varA_value = int(dev.states["temperature"])
varB_value = indigo.variables[1086851778].getValue(int)
indigo.variable.updateValue(varC, str(varA_value - varB_value))
Tue Nov 10, 2020 3:43 pm
SMUSEBY offline
I changed the varC line as suggested, but did not add "_value" as I understand that to be arbitrary (perhaps I'm mistaken?), and got the following error message in the event log - which I'm guessing is more syntax?:
Script Error FD lrTempStatus.py: Python argument types in
VariableCmds.updateValue(VariableCmds, int, int)
did not match C++ signature:
updateValue(_VariableCmds {lvalue}, boost::python::api::object elem, CCString value)
FD lrTempStatus.py, line 47, at top level
ArgumentError: Python argument types in
Line 47:
Tue Nov 10, 2020 3:50 pm
Matt forgot to convert the result to a string (all variable values are strings). I've updated his post to do this.
Tue Nov 10, 2020 4:02 pm
SMUSEBY offline
The script is not updating varC, but first (maybe related) there's another issue:
Trigger run a script
Script Error FD lrTempStatus.py: invalid syntax
Script Error around line 145 - "pass"
Lines 58-144 are commented out. No idea what line 145 has in it.
Tue Nov 10, 2020 4:05 pm
You'll need to copy/paste the contents of the script (file FD lrTempStatus.py it looks like?) for us to see what is wrong.
Tue Nov 10, 2020 4:06 pm
SMUSEBY offline
Sorry - I wasn't clear. Line 144 is the last line (using BBEdit).
Tue Nov 10, 2020 4:12 pm
Add a couple of blank lines (returns) after that line and see if that fixes it.
Tue Nov 10, 2020 4:45 pm
SMUSEBY offline
Below is the entire script (there is no line 11 on the BBEdit screen). Do I understand correctly that Indigo will be updated by a script until the script halts? - or does a script need to complete before updating Indigo? Because the varC is not updating, I'm assuming I still have a syntax issue.
#varA
lRmCld_limit = indigo.variables[1086851778].getValue(int) #livingRm COLD threshhold
dev = indigo.devices[883519697] #living room
#varB
lRmT = int(dev.states["temperature"])
FD_lRm_coldStatus = indigo.variables[515949397]
#FD_lRm_warmStatus = indigo.variables[709335199]
#varC
indigo.variable.updateValue(515949397, str(lRmT - lRmCld_limit)
I get the result:
Script Error around line 11 - "pass"
Tue Nov 10, 2020 4:47 pm
SMUSEBY offline
Nope. (added 3 lines)
Nov 10, 2020 at 14:46:54
Script Error around line 14 - "pass"
Tue Nov 10, 2020 5:00 pm
You need a closing bracket right at the end.
Your last line has 2 open brackets but only 1 closing.
This line is missing a final ')'
Should be
indigo.variable.updateValue(515949397, str(lRmT - lRmCld_limit))
The script posted above is correct, you dropped the parenthesis.
Tue Nov 10, 2020 5:04 pm
SMUSEBY offline
My python always ends up an embarrassment.
Thanks to all of you.
Bob
