Removing seconds from time when copying to variable
Wed Jan 29, 2020 9:11 am
indigobo offline
Hello,
I am using a script which works perfectly, however I do not want the seconds to be included. I have tried removing the %S in the code (see below) but that just results in an error. Any help would be appreciated!
from datetime import datetime
startTimeVariable = indigo.variables[403061892].value  # variable SleepTimeStart
endTimeVariable = indigo.variables[1302608487].value  # variable SleepTimeStop
   startTime = datetime.strptime(startTimeVariable, "%m-%d %H:%M:%S")
except StandardError, e:
    indigo.server.log(u"Error Converting Start Time ('%s'). Error='%s'" % (startTimeVariable, e), isError=True)
    return
   endTime = datetime.strptime(endTimeVariable, "%m-%d %H:%M:%S")
    indigo.server.log(u"Error Converting End Time ('%s'). Error='%s'" % (endTimeVariable, e), isError=True)
    return
if endTime > startTime:
    deltaTime = endTime - startTime
    indigo.variable.updateValue(992740824, str(deltaTime))  # variable SleepTimeAmount
    indigo.variable.updateValue(992740824, value="end Time is before start time")
Wed Jan 29, 2020 10:06 am
Re: Removing Second When Copying To Variable
I think the easiest way is to use the Python format specifier. Change this line:
to this:
indigo.variable.updateValue(992740824, u"{0:%Y-%m-%d %H:%M}".format(deltaTime))  # variable SleepTimeAmount
Untested, but that should work.
Wed Jan 29, 2020 8:31 pm
indigobo offline
Thank you so much for your help! I replaced the line of code with the suggested line but when I it's run it throws an error "invalid conversion specification"
Wed Jan 29, 2020 9:04 pm
Re: Removing seconds from time when copying to variable
Apologies. That is indeed invalid for a timedelta object. This is a bit of a kludge, but it should work.
    newDeltaTime = ':'.join(str(deltaTime).split(':')[:2])
    indigo.variable.updateValue(992740824, newDeltaTime)  # variable SleepTimeAmount
Thu Jan 30, 2020 10:08 am
Here's another option for calculating just the hours and minutes of a timedelta object:
hours, remainder = divmod(td.seconds, 3600)
minutes, seconds = divmod(remainder, 60)
hour_minute_str = "{}:{}".format(hours, minutes)
Sat Feb 01, 2020 7:03 am
indigobo offline
Hey Dave & Jay,
Sorry, I just got around to implementing the above code (saw something shiny and had to follow it).
The code works perfectly and is exactly what I needed. Thank you!!
