- Code: Select all
import time
time.sleep(5)
I also tried
- Code: Select all
indigo.server.getTime()
getTime.sleep(5)
Time.sleep(5)
and, once again, my guess and check has come up with nothing.
Suggestions?
import time
time.sleep(5)
getTime.sleep(5)
Time.sleep(5)
season = indigo.variables[325456157].value
hseOcc = indigo.variables[612296111].getValue(bool)
import Time
# now = indigo.server.getTime()
# get the trigger values (trigXXX: abbreviation for FD low point trigger)
trigHsmp = indigo.variables[658575084].getValue(int) #htr sump COLD threshhold
OkHsmp = indigo.variables[1115411517].getValue(int) #htr sump OK
trigHtWtr = indigo.variables[295376955].getValue(int) #htWtrTank COLD threshhold
OkHtWtr = indigo.variables[154728201].getValue(int) #htWtrTank OK
trigLrm = indigo.variables[1086851778].getValue(int) #livingRm COLD threshhold
OkLrm = indigo.variables[711165647].getValue(int) #livingRm OK
trigStWtr = indigo.variables[25559805].getValue(int) #streetWater COLD threshhold
OkStWtr = indigo.variables[483412678].getValue(int) #streetWater OK
trigUpStrs = indigo.variables[840732144].getValue(int) #upstairs COLD threshhold
OkUpStrs = indigo.variables[63463463].getValue(int) #upstairs OK
trigWcab = indigo.variables[415421705].getValue(float) #wineCabinet COLD threshhold
OkWcab = indigo.variables[364969593].getValue(float) #wineCabinet OK
trigOutside = indigo.variables[680985657].getValue(int) #outside COLD threshhold
OkOutside = indigo.variables[78723147].getValue(int) #outside OK
trigCrwlSpc = indigo.variables[427855415].getValue(int) #crawlSpace COLD threshhold
OkCrwlSpc = indigo.variables[1756484536].getValue(int) #crawlSpace OK
statSetPt = indigo.variables[453519410].getValue(int) #stat set point (from var, not stat)
# get the current temperatures (xxxC: abbreviation for space temp)
dev = indigo.devices[647163782] #street water
stWtrC = int(dev.states["temperature"])
dev = indigo.devices[895358553] #wine cabinet
wineCabC = int(dev.states["temperature"])
dev = indigo.devices[883519697] #living room
lrC = int(dev.states["temperature"])
dev = indigo.devices[634066077] #upstairs
upStrsC = int(dev.states["temperature"])
dev = indigo.devices[1969337208] #outside
outC = int(dev.states["temperature"])
dev = indigo.devices[892742387] #hot water tank
htWtrC = int(dev.states["temperature"])
dev = indigo.devices[1386749935] #heater sump
sumpC = int(dev.states["temperature"])
dev = indigo.devices[46322275] #crawl space
crwlSpcC = int(dev.states["temperature"])
# verify that the variables have been imported properly
indigo.server.log(" season: {}".format(season))
indigo.server.log(" trigOutside: {}".format(trigOutside))
indigo.server.log(" outC: {}".format(outC))
indigo.server.log(" trigCrwlSpc: {}".format(trigCrwlSpc))
indigo.server.log(" crwlSpcC: {}".format(crwlSpcC))
indigo.server.log(" lrC: {}".format(lrC))
indigo.server.log(" trigUpStrs: {}".format(trigUpStrs))
indigo.server.log(" upStrsC: {}".format(upStrsC))
indigo.server.log(" trigHsmp: {}".format(trigHsmp))
indigo.server.log(" sumpC: {}".format(sumpC))
indigo.server.log(" trigHtWtr: {}".format(trigHtWtr))
indigo.server.log(" htWtrC: {}".format(htWtrC))
indigo.server.log(" trigWcab: {}".format(trigWcab))
indigo.server.log(" wineCabC: {}".format(wineCabC))
indigo.server.log(" trigStWtr: {}".format(trigStWtr))
indigo.server.log(" stWtrC: {}".format(stWtrC))
# proceed with the if/then turn off heat for anything that is OK (> FD OK test) w AG
if stWtrC > OkStWtr:
indigo.actionGroup.execute(358770212) #stWtr tape off
if wineCabC > OkWcab:
indigo.actionGroup.execute(955423681) #wine can htr off
if sumpC > OkHsmp:
indigo.actionGroup.execute(172000814) #htr sump tape off
if not hseOcc:
if lrC > OkLrm or upStrsC > OkUpStrs:
indigo.actionGroup.execute(431011597) #htr 5C
if htWtrC > OkHtWtr:
indigo.actionGroup.execute(460903989) #htWtr off
# next, proceed with the if/then turn on heat for anything that is cold (fails FD test) w AG
if season == "winter":
if lrC < trigLrm or upStrsC < trigUpStrs:
indigo.actionGroup.execute(1307638528) #htr 7, cntr, main water off
if sumpC < trigHsmp:
indigo.actionGroup.execute(1808251937) #htr sump tape on, cntr
if htWtrC < trigHtWtr:
indigo.actionGroup.execute(599509902) #htWtr On, cntr
if stWtrC < trigStWtr:
indigo.actionGroup.execute(90585841) #stWtr tape on, cntr, water off
if wineCabC < trigWcab:
indigo.actionGroup.execute(1406401903) #wine can htr on, cntr
#last, send email notifications f(FD condition)
time.sleep(5) #allow time for devices to switch on as necessary before reporting their status
if (lrC < trigLrm or \
upStrsC < trigUpStrs or \
crwlSpcC < trigCrwlSpc or \
outC < trigOutside or \
sumpC < trigHsmp or \
htWtrC < trigHtWtr or \
stWtrC < trigStWtr or \
wineCabC < trigWcab ):
indigo.actionGroup.execute(966172245) #if any cond faile, sends FD email
# if lrC > trigLrm:
# indigo.actionGroup.execute(1279658637) #elephant light ON autoOFF
elif (outC > OkOutside):
indigo.actionGroup.execute(1538967727) #not cold email
indigo.actionGroup.execute(963098824) #all temps ok email
