Python - getting a device state
Sun Oct 06, 2019 10:03 pm
SMUSEBY offline
The Phidgets devices have a device state, 'state' - see attachment.
The following code -
season = indigo.variables[525524114].value
lrTemp = indigo.devices[883519697].state.getValue(int)
if season == "winter":
   if lrTemp < 7:
      indigo.actionGroup.execute(1011316617)
produces the error message, "hseHeaterON13.py, line 2, at top level
AttributeError: 'Device' object has no attribute 'state'.'
I get the same error substituting 'temperature' for 'state'. I've verified the device number.
What error am I making now?
Note: I'm attempting to use Python because Indigo's conditional logic is failing (giving true when it should be false). My guess is that Indigo is treating the integer temperature value as a string.
Sun Oct 06, 2019 10:52 pm
Re: Python - getting a device state
this should work:
dev = indigo.device[883519697]
lrTemp = int(dev.state["temperature"])
   if lrTemp < 7:
Mon Oct 07, 2019 7:33 am
Kar'ls has a typo – needs and 's' on the end of state:
lrTemp = int(dev.states["temperature"])
   if lrTemp < 7:
Looks like that device has two states "temperature" and "state." In your screenshot they both have the same value so I'm not sure how or if they are different, but the 3rd line above could also be:
lrTemp = int(dev.states["state"])
Mon Oct 07, 2019 3:33 pm
SMUSEBY offline
Error message: 'DeviceCmds' object does not support indexing
Exception Traceback (most recent call shown last):
test hseHeaterON13.py, line 6, at top level
TypeError: 'DeviceCmds' object does not support indexing
No idea how to approach this error message.
Mon Oct 07, 2019 3:44 pm
CliveS offline
Replace
with
dev = indigo.devices[883519697]
(another missing 's')
CliveS
Mon Oct 07, 2019 5:18 pm
SMUSEBY offline
   if lrTemp > 7:
      indigo.device.turnOn(166867032) #counter light
      indigo.device.turnOff(1230957473) #doorlight
Adding the 's' fixed the error message. Now it simply doesn't do as intended.
Testing various formulations of the code, i have determined there are now 2 problems:
1) The season test passes 'false' when it is 'true',
2) the else syntax is not working
Mon Oct 07, 2019 5:43 pm
## add a logging statement to see what is happening:
indigo.server.log(" lrTemp: {}".format(lrTemp))
indigo.server.log(" season: {}".format(season))
   if lrTemp > 7:
Mon Oct 07, 2019 6:34 pm
SMUSEBY offline
Brilliant - I was struggling the the log statement, and it did the trick.
Thank you!
Mon Oct 07, 2019 8:02 pm
some times you have a blank at the end in a variable
then use:
indigo.server.log(" season:>{}<".format(season))
you can see if there are any spaces present eg >winter <
Mon Oct 07, 2019 8:21 pm
and to get rid of spaces and if you want to ignore upper / lower case:
if season.strip().lower()== "winter":
Mon Oct 07, 2019 8:45 pm
SMUSEBY offline
I meant that I was struggling with logging info to debug my little script, and suddenly, there was your snippet. Your snippet ran right out of the box.
