help request - debug python script
Wed Oct 02, 2019 10:21 pm
SMUSEBY offline
I'm trying to manage a variable, hseOcc as follows: if true, make it false, else make it true.
My attempt:
hseOcc = indigo.variables[612296111].getValue(bool)     #
if hseOcc = true: # I also tried "true", and 1
    indigo.variables.updateValue[612296111] = false #
   else
    indigo.variable.updateValue(612296111) = true #
gives me an invalid syntax error.
Eliminating all but the first line also produces a syntax error.
Using the Extending Indigo documents, I tried:
hseOcc = indigo.variable[612296111]
if hseOcc == "true":
    indigo.variable.updateValue[612296111], "false" #
    indigo.variable.updateValue(612296111), "true" #
The log error for this is"embedded script, line 1, at top level
TypeError: 'VariableCmds' object does not support indexing.
Suggestions?
BTW, I know I could do this with triggers, but I'm still determined to make something work with Python. This seems like an easy problem and learning opportunity for me.
Bob
Wed Oct 02, 2019 10:50 pm
Re: help request - debug python script
Bool values in python are True and False. Upper case .. not true false
Wed Oct 02, 2019 11:28 pm
SMUSEBY offline
modified to:
if hseOcc == "True":
    indigo.variable.updateValue[612296111], "False" #
    indigo.variable.updateValue(612296111), "False" #
It is crashing of the first line, with the message, "embedded script: 'VariableCmds' object does not support indexing. Not sure what that means, but I tried the alpha name for the variable, and got the same error.
Wed Oct 02, 2019 11:30 pm
SMUSEBY offline
Correction: using the alpha name of the variable, the error is "embedded script: global name 'hseOccupied' is not defined"
Sorry.
Thu Oct 03, 2019 12:34 am
Try this:
if hseOcc:
    indigo.variable.updateValue(612296111, value="False")
    indigo.variable.updateValue(612296111, value='True')
The if hseOcc: line can be written as if hseOcc is True:.
Using device name instead of device id, the code would look like this:
hseOcc = indigo.variables["hseOccupied"].getValue(bool) #
if hseOcc:
    indigo.variable.updateValue("hseOccupied", value="False")
    indigo.variable.updateValue("hseOccupied", value='True')
Hope this helps. :)
EDIT: Added device name example code above.
Thu Oct 03, 2019 11:48 am
SMUSEBY offline
I changed the if line as suggested, but the script crashes on the first line:
hseOcc = indigo.variable[hseOccupied]
results in the error message, "embedded script: global name 'hseOccupied' is not defined". How do I fix this?
Thu Oct 03, 2019 12:00 pm
FlyingDiver online
What happened to the quotes around the name hseOccupied in that line? It was in the code autolog posted. Also, you dropped the 's'. It should be:
And, yet again, USE THE CODE TAG when posting code snippets.
Screen Shot 2019-10-03 at 2.00.59 PM.png (18.59 KiB) Viewed 2916 times
Thu Oct 03, 2019 12:30 pm
SMUSEBY offline
I'm very sorry - I'm asking for help, and clearly violating protocol. Doing my best, and trying to learn.
Is this what you want?
if hseOcc is True:
To repeat my question, the code crashes on the first line - 'global name 'hseOccupied' is not defined. If I replace the variable name with the ID, the error is, "embedded script: 'VariableCmds' object does not support indexing".
Thu Oct 03, 2019 12:34 pm
FlyingDiver online
Yes.
if hseOcc is True:
See my previous answer. You have two problems. You dropped the 's' from the indigo.variables dictionary name, and you need the key for the dictionary to be either a variable ID (an integer) OR a string. You put in an undefined Python variable. Again, it needs to be:
Once you fix that, then you need to fix the lines to set the Indigo variable. You're using brackets instead of parenthesis, and you have the replacement value outside the function call.
if hseOcc is True:
    indigo.variable.updateValue(612296111, "False")
Thu Oct 03, 2019 1:02 pm
SMUSEBY offline
Solved issues in first line - thank you.
Now the problem is line 2 - the the conditional test is not working: the variable ="True", and it is not being changed to "False" in line 3.
if hseOcc is True:
    indigo.variable.updateValue(612296111, "True")
if I modify the script to:
if hseOcc is True:
    indigo.variable.updateValue(612296111, "xyz")
it assigns xyz to the hseOccupied variable. There must be something wrong with line 2.
Thu Oct 03, 2019 1:11 pm
FlyingDiver online
if hseOcc is True:
if hseOcc is True:
Your line 1 is getting a reference to the Indigo variable, not the value of the variable. If you want to use the value of the variable as a boolean (as Line 2 is written) then it should be:
if hseOcc:
In this case, instead of getting the reference to the variable, the method call (.getValue()) returns the value interpreted to be a boolean. And since it's a boolean now, you don't need to compare it to another boolean, you can just use it for the conditional as is.
Thu Oct 03, 2019 1:19 pm
Hi Bob,
SMUSEBY wrote:
... BTW, I know I could do this with triggers, but I'm still determined to make something work with Python. This seems like an easy problem and learning opportunity for me. ...
If you refer to my answer above, you will see I already showed you how to do it. :wink:
You need to make sure that you copy the code presented to you and then you would likely get to the answer much quicker. :)
You may find this documentation helpful for future reference: Variables :)
Thanks @FlyingDiver for your patient assistance. :)
Thu Oct 03, 2019 2:11 pm
SMUSEBY offline
It works - thank you for your help and patience.
I am now working on a conditional script that involves strings. It runs without errors, but it is not turning on the device. In the variables link you referenced, I don't see anything equivalent to the get.value(bool) for strings. I think I'm following the syntax, but...
Script Objective, in English: if the valve is 'closed' AND if the season is not 'summer' (both string values), I want to turnOn a device.
season = indigo.variables[325456157]
Valve = indigo.variables[1371508015]
if Valve == "closed":
   if season.value != "summer":
      indigo.device.turnOn(1437097498)
Thu Oct 03, 2019 2:19 pm
FlyingDiver online
Again, your lines 1 and 2 are getting a reference to the Indigo variable, not the value of the variable. Indigo variables are natively strings, so if you want the string value, you just do:
Valve = indigo.variables[1371508015].value
Your season test is fine. You missed .value on the valve test.
Thu Oct 03, 2019 2:50 pm
SMUSEBY offline
I see - the value is either in the variable definition or the test.
Thanks.
