Find device by address (z-wave)
Wed Apr 18, 2018 11:59 am
brettlid offline
Anyone know how to locate a device by using it's z-wave address other than iterating thru the entire device list.
Wed Apr 18, 2018 12:08 pm
Colorado4Wheeler offline
Re: Find device by address (z-wave)
Not really, but you can refine the iteration:
for dev in indigo.devices.iter("indigo.zwave"):
  if dev.address == 1234:
    do something....
Fri Apr 20, 2018 12:31 am
All my Zwave plugins use six dicts at startup, two of which are:
devFromNode[node] = devID
nodeFromDev[devID] = node
That way, wherever I have the node ID of a device, eg an incoming Zwave Command, I can turn it instantly into a device ID, or vice-versa, without having to iterate Indigo.devices[] every time.
The other four are identical but convert to/from my own plugin device IDs.
That might help you?
Fri Apr 20, 2018 5:58 am
Good tip. Our main Z-Wave plugin library does something similar.
