Attempting to code Python to use API data
Sun Jan 28, 2018 2:25 pm
towsled offline
I have an EKM Metering system monitoring my gas and electric and decided that I would try and access the system in Indigo. EKM provides an API (ekmmeters.py) which I thought I would code up in Python (I am very new to coding Python). So far I have installed ekmmeters.py in Xcode and imported the sample code from their manual into Indigo (copied below). It appears that when I attempt to run the basic script (opens and then closes the connection to the meter) it is not recognizing the ekmmeters.py module. I am sure that I am missing something simple but could use help getting pointed in the right direction.
Dan..
____________________________
import os      # to delete example db before create
import random  # to generate example data
import time    # to support summarizer sample
from ekmmeters import *
my_port_name = "/dev/ttyS0"
my_meter_address = "300001162"
ekm_set_log(ekm_print_log)
port = SerialPort(my_port_name)
if (port.initPort() == True):
    my_meter = V4Meter(my_meter_address)
    my_meter.attachPort(port)
    print "Cannot open port"
    exit()
# Example goes here
port.closePort()
Sun Jan 28, 2018 3:11 pm
Re: Attempting to code Python to use API data
I think we need a little bit more information on how you're trying to proceed. How are you trying to access the script from within Indigo?
If you access your script as a file and have the other file in the same folder, Indigo should be able to recognize it.
Sun Jan 28, 2018 3:24 pm
Colorado4Wheeler offline
And it depends on where ekmmeters.py is. Is it a package? If so it may be more along the lines of import ekmmeters rather than from ekmmeters import *. You should get an error when you try to load the file if it's not loading properly - what is that error?
Also watch your indents in Python, it's pretty important:
exit()
Should be more like:
     exit()
Sun Jan 28, 2018 3:57 pm
towsled offline
Thanks for the replies. The framework I am following has the shell listed in the previous note and then specific language inserted at the #Example goes here point. Here is the error I get in the Log when trying to run the script from within Indigo:
_________________
Script Error                    embedded script: No module named ekmmeters
embedded script, line 6, at top level
ImportError: No module named ekmmeters
__________________
The manufacturer provided the following example of language to request data from the meter (below). Results are returned in hex and then must be parsed.
# Open connection to serial port
# Change /dev/ttyUSB0 to match your system
sp = serial.Serial(
    port='/dev/ttyUSB0',
    baudrate=9600,
    parity=serial.PARITY_EVEN,
    stopbits=serial.STOPBITS_ONE,
    bytesize=serial.SEVENBITS,
    xonxoff=0,
    timeout=5
# Meter Number
meter="000300001184"
# Send Request A to v4 Meter
sp.write("\x2F\x3F"+meter+"\x30\x30\x21\x0D\x0A")
# Get meter response
response = sp.read(255)
# Show response
print(" ".join("{0:02x}".format(ord( c )) for c in response))
# Send close to meter
sp.write("\x01\x42\x30\x03\x75")
# Close connection to serial port
sp.close
Thanks again for the help!
Dan..
Sun Jan 28, 2018 4:16 pm
towsled offline
Point well taken on the spacing and format.. For some reason I loose the spacing when I cut the code out of the compiler window and paste here. :D
Sun Jan 28, 2018 4:30 pm
If you block select the code segments and then click the Code button above, the spacing and format will be preserved.
Sun Jan 28, 2018 6:39 pm
I edited your posts to place the code between code tags so you can see how those work for future posts.
Mon Jan 29, 2018 10:57 am
After giving this some thought, I think I might know what's going on. In Python 2.x (I don't know about all Python 2 versions; for this example, I'm using Indigo 7 and Python 2.7). Consider two files, both of which reside in the same folder:
foo.py
#! /usr/bin/env python
# -*- coding: utf-8 -*-
from foo1 import *
print(u"foo")
foo1.py
print(u"foo1")
When I run foo.py from the terminal, I get the following result:
Daves-MacBook-Air:Scripts dave$ python foo.py
foo1
foo
When I run foo.py as an embedded script within Indigo, I get the following result:
   Script Error                    foo.py: No module named foo1
     foo.py, line 4, at top level
ImportError: No module named foo1
The Python interpreter will search the current folder (the one where the scripts reside) as a part of the search path, but it doesn't appear this is the case when running the script as an embedded script in Indigo. Further, there are rules about how imports work when the folder is considered a Python package (or not).
I believe there are a couple of different ways to handle your case (there are others but I think these are the best): you could write your code as a plugin, place your scripts in a folder included in the default sys.path, or you could use absolute imports as opposed to relative. Here is a nice explanation of the ins and outs of Python imports.
Any Python gurus out there (I'm not one) should feel free to correct anything I've said here.
Mon Jan 29, 2018 11:27 am
racarter offline
If you want to import from a custom Python file into an embedded or external Python script called from Indigo, try placing the file in the /Library/Python/2.7/site-packages folder. (2.7 works for me but you might need to experiment.)
Mon Jan 29, 2018 12:00 pm
This is correct for Indigo 7. For Indigo 6 or earlier, it's:
/Library/Python/2.5/site-packages
Mon Jan 29, 2018 4:26 pm
towsled offline
Thanks all for the great advice! I will try the suggestions later on tonight and report back what I find.
Thanks again,
Dan..
