Applescript Conversion
Fri Dec 22, 2017 4:45 am
ckeyes888 offline
Having quite o few of this type of AS I'd appreciate any help in converting it to Python.
   if the value of variable "Awake" is "true" and the value of variable "NightstandLight" is "0" then
      dim device "Bedroom Upstairs Nightstand Light" to "100"
   else
      if the value of variable "Awake" is "true" and the value of variable "NightstandLight" is "100" then
         dim "Bedroom Upstairs Nightstand Light" to "40"
      else
         if the value of variable "Awake" is "true" and the value of variable "NightstandLight" is "40" then
            dim "Bedroom Upstairs Nightstand Light" to "100"
         else
            if the value of variable "Awake" is "false" and the value of variable "NightstandLight" is "0" then
            else
               if the value of variable "Awake" is "false" and the value of variable "NightstandLight" is "40" then
               else
                  if the value of variable "Awake" is "true" and the value of variable "NightstandLight" is "off" then
                  end if
               end if
            end if
         end if
      end if
   end if
end tell
Carl
Fri Dec 22, 2017 7:12 am
Re: Applescript Conversion
There are several ways to go about this--here is a (somewhat) literal conversion. Obviously, I can't test it.
awake = indigo.variables["Awake"].value
night_stand_light = indigo.variables["NightstandLight"].value
if awake == "true" and night_stand_light == "0":
    indigo.dimmer.setBrightness("Bedroom Upstairs Nightstand Light", value=100)
if awake == "true" and night_stand_light == "100":
    indigo.dimmer.setBrightness("Bedroom Upstairs Nightstand Light", value=40)
if awake == "true" and night_stand_light == "40":
if awake == "false" and night_stand_light == "0":
if awake == "false" and night_stand_light == "40":
if awake == "true" and night_stand_light == "off":
Once you convert the script to Python, it's good practice to use device and variable ID numbers rather than their names. It gives you greater protection against something breaking if the name of a device or variable should change. So you can (in my opinion, *should*) change: "Awake", "NightStandLight", and "Bedroom Upstairs Nightstand Light" to the corresponding ID numbers.
Please feel free to post back with any questions.
Fri Dec 22, 2017 7:19 am
How is this script run? I don't think you actually need a script to do this. You could do it with multiple schedules or triggers.
Also, I think the script is either broken or redundant. Here's a table of the two inputs and the output:
Awake       NightStandLight     Light
true        0                   100
true        100                 40
true        40                  100
false       0                   40
false       40                  100
true        off                 100
Looks like a value of 40 for the Light variable always sets it to 100, regardless of the value of awake. And since 0 == off, the last conditional shouldn't be needed.
awake = indigo.variables[123]
NightStandLight = indigo.variables[456]
lightDevice = indigo.devices[7890]
if awake.value == "true" and NightStandLight.value == 0:
    indigo.dimmer.setBrightness(lightDevice, value=100)
elif awake.value == "true" and NightStandLight.value == 100:
    indigo.dimmer.setBrightness(lightDevice, value=40)
elif awake.value == "false" and NightStandLight.value == 0:
elif NightStandLight.value == 40:
Fri Dec 22, 2017 9:24 pm
ckeyes888 offline
Thanks a bunch all. Works great.
Now on to adapting the script to a hundred others. :?
Carl
