Using Python to add heating variables into Variable List
Mon Nov 20, 2017 4:09 pm
CliveS offline
I have an action to put my Evohome Radiator Setpoint and Actual (live) readings into the Variable List, works fine but I would like to do the same via a Python embedded script.
The Action is
Insert state (temperatureinputsall) for device ‘ev.zone: bathroom’ into variable: bathroom_temperature_live
Insert state (setpointheat) for device ‘ev zone: bathroom’ into variable: bathroom_temperature_setpoint
But I cannot get my head around the Python coding have tried everything I can think of without success.
CliveS
Mon Nov 20, 2017 4:53 pm
Re: Using Python to add heating variables into Variable List
Hi Clive - we'll get you going. Here's a sample to update a variable value:
dev = indigo.devices[1149686816]
var = indigo.variables[1961258112]
value = dev.states["windSpeed"]
indigo.variable.updateValue(var, str(value))
Obviously, you'll need to update the device and variable lines with the Indigo IDs of your source and target, and change the device state to match your use case. It's a little tough to know where you stumbled; if I had to guess, I'd bet it's because you didn't convert the state values into a string before trying to save the value to the variable. In Indigo, every variable value is a string and trying to save anything else to a variable will result in an error.
But if I might ask, why do you need to put a state value into a variable? Why not work with the state directly?
