Python from other apps to control Indigo
Mon Oct 09, 2017 12:00 pm
nev offline
Hi All,
I'm trying to convert all my applescripts to python and must be missing something. I am currently working on my HamBridge server app which used AppleScript to tell Indigo to change variable values based on http calls it got from various APIs. All I'm trying to do it have it update a variable value, but i get is ab error "Name 'Indigo' is not defined"
#! /usr/bin/env python
import commands,os,random,sys
myVar = indigo.variables["home"]
indigo.variable.updateValue(myVar,false)
myVar.refreshFromServer()
How do i get this to work?
Mon Oct 09, 2017 12:13 pm
Re: Python from other apps to control Indigo
The "indigo.***" APIs are only available from a special Indigo based python environment. Indigo plugins and Indigo actions that execute python scripts provide that environment automatically (we call it the indigohost or IndigoPluginHost/IPH). If you need to initiate a python script from outside Indigo you can use the indigohost. See this section of the plugin tutorial for some details.
Once you've defined the indigohost alias, which just makes calling it simpler, you can execute python code either embedded or using the indigohost to specify a python file for execution (with the indigo.*** APIs available).
Fri Dec 01, 2017 2:19 pm
nev offline
This works well for me to control variables in indigo from other applications.
curl -u <username>:<password> --digest -X PUT -d value=false http://serverIP:8176/variables/<variable_name>
How do I use this type of method to trigger an Action Group?
Fri Dec 01, 2017 2:29 pm
roussell offline
I don’t believe the guys have implemented action groups through REST yet. What I do is create a virtual device, and have that virtual device trigger an action group. You can then switch the virtual device using a variation of your curl statement. You could also change an Indigo variable, then have a trigger watching that variable and fire off the action group.
Terry
Fri Dec 01, 2017 3:43 pm
curl -u <username>:<password> --digest -X EXECUTE http://127.0.0.1:8176/actions/party%20scene
Fri Dec 01, 2017 3:44 pm
Check out the RESTful API docs for examples of everything it can do.
Fri Dec 01, 2017 4:24 pm
roussell offline
Cool!! Guess I’ve got some updates to do too!
Terry
Fri Dec 01, 2017 7:01 pm
nev offline
Perfect!!!! Thanks so much.
