I have a useful Javascript for Loop Energy but have no idea
Thu Sep 28, 2017 8:26 am
Busta999 offline
I am at a total loss on how to use this in Indigo :-(
I am not a scripting guy .... :oops:
This javascript is supposed to be able to get my realtime energy usage every 10 seconds for Elec and every 15 minutes for Gas.
Can anyone help me get this into Indigo and be able to use Matplotlib to graph it?
Here is the script ( I have the serial and secrets for both Elec and Gas.
// Subscribe to electricity and gas streams on Navetas Loop websockets
// Secrets and serial numbers can be found by logging into your-loop.com
// and evaluating the 'Drupal.settings.navetas_realtime' variable in browser console.
require( "console-stamp" )( console, { pattern : "dd/mm/yyyy HH:MM:ss.l" } );
var io = require('socket.io-client');
console.log('Starting');
var elec_serial = 'xxx';
var elec_secret = 'xxx';
// var gas_serial = 'xxx';
// var gas_secret = 'xxx';
// Need version 0.9.16, newer versions incompatible
var socket = io.connect('https://www.your-loop.com', {reconnect: true});
// Connect
socket.on('connect', function(){
  console.log('Connecting');
  // Subscribe to electricity readings in watts
  socket.emit("subscribe_electric_realtime", {
    serial: elec_serial,
    clientIp: '127.0.0.1',
    secret: elec_secret
  // Subscribe to gas readings
  // socket.emit("subscribe_gas_interval", {
  //   serial: gas_serial,
  //   clientIp: '127.0.0.1',
  //   secret: gas_secret
// Output electricity readings (~1 per 10 seconds)
socket.on('electric_realtime', function(data) { console.log("Electricity:%j", data);});
// Output gas readings (much slower ~15 mins)
socket.on('gas_interval', function(data) { console.log("Gas:%j", data);});
// Disconnect
socket.on('disconnect', function(){ console.log("Disconnected.");});
