Lost in iTunes
Wed Sep 27, 2017 9:34 am
Different Computers offline
Lost in iTunes
Hey all,
I just tried to start understanding viewtopic.php?f=107&t=13889&start=15 and, well, I failed. Is it even the right direction to go in order to duplicate this typical functionality?
tell application "iTunes"
   if player state = playing then
      --copy (get rating of current track) to trackRating
      -- repeat with theTrack in (get selection)
      set the rating of current track to ((rating of current track) - 20)
      set trackRating to (rating of current track)
         set value of variable "iTunesStars" to trackRating / 20
      end tell
      -- end repeat
   end if
end tell
Short version of that code: It's an example of one of several things about iTunes that the iTunes integration doesn't cover. So now I'm wondering how to get and manipulate these values with Python. I get that it's the last "tell" that is the part that has to move to Python. But can I do it all in Python?
Wed Sep 27, 2017 11:00 am
Re: Lost in iTunes
If you install the py-applescript module (which will ship with Indigo 7.1) as described in the AppleScript blog post, then this script will get the rating of the current track and insert it into a variable:
import applescript
script_source = '''
end tell
compiled_script = applescript.AppleScript(source=script_source)
reply = compiled_script.run()
indigo.variable.updateValue(VARIDHERE, value=str(reply))
The value inserted in the variable will be whatever is returned by "rating of current track".
Wed Sep 27, 2017 1:48 pm
norcoscia offline
Re: Lost in iTunes
Is it possible to locate any items that contain any AppleScript w/o manually opening and looking in the 5 million places I might have cut and pasted some of it into - pls say yes, pls say there will be a zippy dippy AppleScript locater thingy in Indigo 7.1
_______
Norm
Wed Sep 27, 2017 2:56 pm
Re: Lost in iTunes
We're looking in to it. It may not be part of the 7.1.0 release, but we'll look at doing something in the 7.1.x releases or potentially a separate script that just runs against an Indigo database file. But we'll figure something out.
Wed Sep 27, 2017 3:39 pm
norcoscia offline
Re: Lost in iTunes
Wow, cool - thx so much!
_______
Norm
