Set Wake Interval from Python?
Mon Sep 25, 2017 5:06 am
sgbirch offline
Can the device Wake Interval be changed from a python script?
Mon Sep 25, 2017 5:53 am
Re: Set Wake Interval from Python?
Hi - You'll need to provide a bit more detail for your use case. What kind of device? What protocol?
For Z-Wave, search the forums for sendRawZwaveCommand which might yield you some examples that will work for your situation. However, I'd recommend a slightly different approach. Create an Action --> Z-Wave Action --> Modify Configuration Parameter and fill in the dialog as needed. Then execute the Action from Python...
If you need to change it to different values based on some other criteria, then I think sendRawZwaveCommand() is going to be your best approach.
Mon Sep 25, 2017 9:28 am
Depending on your needs, go to my plugins and you’ll find one (whose name I’ve forgotten) that simply sets the wake interval.
Can be used in action groups etc.
I knocked it up for another user who has his devices waking more frequently daytime than nighttime; can’t recall the scenario.
Users browsing this forum: No registered users and 24 guests
