Dipping a toe in, floundering
Sun Sep 10, 2017 3:27 pm
Different Computers online
I can probably file this under "a little knowledge is a dangerous thing"
Trying to create a shell script that sends python to Indigo.
#!/bin/sh
python indigo.actionGroup.execute(17622409777)
this results in
Indigo:~ name$ ./kbutton*t
./kbutton.scpt: line 2: syntax error near unexpected token `('
How stupid am I? More to the point, what did I get wrong?
Sun Sep 10, 2017 4:12 pm
Re: Dipping a toe in, floundering
i don't think you can from outside indigo start something inside indigo.
the plugin SATI http://forums.indigodomo.com/viewforum.php?f=185 creates a framework that will read files in
~/documents/sati/fromAS-# ;;; # =1-16
then execute that command from these files within indigo
available commands:
commands in input file fromAS-n supported:
getVariable;:;:;variableName/id
setVariable;:;:;variableName;:;:;value
getDeviceState;:;:;deviceName/id;:;:;stateName
action group
exeAction;:;:;actionName/id
device on/off
turnDeviceOn;:;:;deviceName/id
turnDeviceOff;:;:;deviceName/id
digital output devices
setBinaryOutputOn;:;:;deviceName/id;:;:;index of output pin
setBinaryOutputOff;:;:;deviceName/id;:;:;index of output pin
dimmer
setBrightness;:;:;deviceName/id;:;:;value (0-100)
Thermostats
setHeatSetpoint;:;:;deviceName/id;:;:;value
setCoolSetpoint;:;:;deviceName/id;:;:;value
setFanModeOn;:;:;deviceName/id
setFanModeAuto;:;:;deviceName/id
and for subscriptions:
subscribeDeviceState;:;:;deviceName/id;:;:;stateName;:;:;channel
subscribeDeviceStateDelete;:;:;deviceName/id +stateName
subscribeVariable;:;:;variableName/id;:;:;channel
subscribeVariableDelete;:;:;variableName/id
and for python execute:
execCmd;:;:;pythonCode
devName and varName and actName  can be strings or IDs
";:;:;" is used as a separator
syntax is:
command separator arguments
to execute action group "abc"
put
"exeAction;:;:;abc"
without the "
into file ~/documents/sati/fromAS-1
then the action group abc will be executed.
It was written for AppleScript for 2 way communication to be able to talk to indigo circumventing the "application not active error", but can be used for anything that can create a file.
Sun Sep 10, 2017 4:15 pm
and to initiate python it is:
 python code.py arg1 agr1 agr2
Sun Sep 10, 2017 4:48 pm
Actually, you can just use the IndigoPluginHost to execute a script. Start by creating the indigohost alias (I put that in my .profile so it's always available).
Next, take a look at the args for indigohost:
FatBook:~ jay$ indigohost --help
Allowed options:
  --help                       show this help message
  -f [ --folder ] arg          target plugin folder name (default arg)
  -i [ --interactive ]         run in interactive shell mode
  -d [ --debug_mode ] arg (=0) debugging mode selector
  -e [ --emb_script ] arg      execute arg as embedded script source
  -x [ --ext_script ] arg      execute the target file path arg as an external
                               script
  -p [ --port ] arg (=1176)    indigo server port number
Next, just call it with your script using the -e option:
indigohost -e 'indigo.actionGroup.execute(17622409777)'
Which you can call from a bash script if you want. Note, you can also use this with the -x option to execute an Indigo Python script in a different file (see the args above).
If we had some more context, we might be able to make it even easier... 8)
Advanced Tip
One more cool thing that I don't think is mentioned anywhere else: if you want an Indigo python script to be executable from a shell by changing it's mode to executable, you can do that too. First, create a link to a path that does not contain spaces. I put it:
ln -s /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/IndigoPluginHost.app /usr/local/bin/IndigoPluginHost.app
This creates a path without spaces, which is important for the shebang to work at the top of an Indigo Python script. Add it:
#!/usr/local/bin/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost -x
to the top of the script, make the script executable, and it will now behave like any other unix command. For instance, I have this script:
from time import sleep
indigo.server.log("Starting script")
for i in range(20, 0, -1):
    indigo.server.log("countdown: {}".format(i))
    sleep(1)
saved in ~/jay/Projects/Indigo Scripts/simple_sleep.py. I changed it so that it's executable:
chmod +x ~/Projects/Python/Indigo/simple_sleep.py
so now I can just do:
FatBook:Indigo jay$ ./simple_sleep.py
to run the script. This is useful for other utilities that may require you to specify a single unix command.
Sun Sep 10, 2017 8:10 pm
Cool did not know that.
Sun Sep 17, 2017 9:21 am
jay (support) wrote:
If we had some more context, we might be able to make it even easier... 8).
I got some of those Flic buttons, and they work by triggering scripts. So I need a scripted way of making an action group trigger. Easy for me to do with an AppleScript workflow, but I figured this would be a good way to start learning how to do the same thing with Python.
also I don't mean to sound ungrateful, but the stuff KW wrote is meaningless to me and to continue the "dipping a toe in" metaphor, only seems to me like a suggestion to scuba dive in the deep end.
Sun Sep 17, 2017 9:29 am
@jay, I tried
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
and after exit, then closing the remote terminal window and opening another to try "indigohost -i", I get
-bash: indigohost: command not found
Does this not work remotely? My Indigo box is headless.
Never mind. I got it. I see my default shell wasn't bash for some reason.
Sun Sep 17, 2017 9:47 am
and now I try it and get
Connected to Indigo Server v7.0.3, api v2.0 (localhost:1176)
>>> indigohost -e 'indigo.actionGroup.execute(1761409777)'
  File "<console>", line 1
SyntaxError: invalid syntax
Sun Sep 17, 2017 10:03 am
It looks like the above you executed in the Indigo plugin scripting shell (opened via the Plugins->Open Scripting Shell menu). Inside that shell the indigo namespace is available, so you would just use:
If you are trying to execute it from a normal bash shell (either Terminal or script), then you need the indigohost -e which is used to pass the command through to Indigo's scripting shell where the indigo namespace is available.
Sun Sep 17, 2017 10:09 am
OK, that worked once I had the shell running.
My script (and note, it's a script I'm trying to call) looks like
#!/bin/bash
fails with
./kbutton.scpt: line 2: indigohost: command not found
it's almost like I have two different bash shells installed. Is that possible?
Doesn't seem to be so:
bash-3.2$ finger md
Login: md                     Name: Mike D
Directory: /Users/md              Shell: /bin/bash
but somehow, my script can't find the indigohost, while I can manually on the command line.
Sun Sep 17, 2017 11:07 am
Remember, you created the indigohost alias in the interactive shell you're running when you log in (via .bashrc). When you execute a shell script the way you have it set up, it's starting a different bash shell process to run the script which doesn't run your local .bashrc, and that shell doesn't know what indigohost is.
Sun Sep 17, 2017 12:35 pm
gotcha.
I know this is outside of straight indigo support, but I'm unclear how to fix this, or even what terms I should search for. How can I tell ALL bash shells where indigohost is, or alternately, specify something besides /bin/bash in the script? No idea what else I would be pointing the script to.
Or should I just put the full path to the command in the script? That seems cumbersome, given that with the equipment I have now (3 Flic buttons) I may ultimately have 9 different scripts. Buttons support 3 actions each.
Sun Sep 17, 2017 12:46 pm
I went ahead and put the full indigohost path in, and now it works.
Thanks for everyone's help, and if you can point me to a resource for learning how to alias this for all shells, I would appreciate it!
Sun Sep 17, 2017 2:06 pm
Again, depending on the exact scenario, you can also follow the Advanced Tip from my post above. That would potentially keep you from having to wrap Indigo python calls in shell scripts by allowing Indigo Python scripts to be executed directly (no aliases needed).
