Send picture files via iMessage?
Sat Sep 09, 2017 1:27 pm
racarter offline
Does anyone know of a Python way to send CCTV snapshot files via iMessage? Currently I do it with AppleScript, but since support for this is being withdrawn I need to change this.
I know I can use py-applescript, but a pure Python solution would be nice.
Sat Sep 09, 2017 1:50 pm
Re: Send picture files via iMessage?
Python has the smtplib module to send emails. The iMessage question has been asked on reddit without a clear answer.
Sat Sep 09, 2017 1:51 pm
Different Computers offline
Being withdrawn? I've only heard strong admonitions from Jay and Matt to move to Python because they're uncertain what Apple is going to do with AppleScript. From what I can tell, it's still supported in High Sierra.
Also, please share these scripts.
Sat Sep 09, 2017 2:05 pm
viewtopic.php?f=4&t=19013
Sat Sep 09, 2017 3:10 pm
racarter offline
@Different Computers
Here's one of my AppleScripts. When the doorbell rings I run a Python script to grab three CCTV snapshots 5 seconds apart, then run this script to send the images via Messages.
set theAttachment1 to POSIX file "/Snapshots/snap1.jpg"
set theAttachment2 to POSIX file "/Snapshots/snap2.jpg"
set theAttachment3 to POSIX file "/Snapshots/snap3.jpg"
tell application "Messages"
   send theAttachment1 to buddy "+441234567890" of service "E:mailaddress@mailserver.com"
   send theAttachment2 to buddy "+441234567890" of service "E:mailaddress@mailserver.com"
   send theAttachment3 to buddy "+441234567890" of service "E:mailaddress@mailserver.com"
end tell
Sat Sep 09, 2017 3:12 pm
racarter offline
Thanks Jay -I saw the Reddit discussion before I posted here. I guess it's the wrapper solution for now...
Sat Sep 09, 2017 5:21 pm
Not sure I'd change anything on the script above since it isn't talking to Indigo...
Sun Sep 10, 2017 1:57 am
racarter offline
The script is currently embedded in a trigger though - so I'll have to wrap it (or change it to external).
Sun Sep 10, 2017 9:13 am
Gusten offline
@racarter would you mind sharing the python script that collects the snapshots from the camera?
Sun Sep 10, 2017 11:10 am
Yes, easiest approach would probably be to make it an external script file (via the Script Editor app). Indigo 7.2+ will be able to execute external AppleScript files. At this point we don't think we'll support embedded AppleScripts (even if they don't target Indigo Server).
Sun Sep 10, 2017 11:45 am
racarter offline
Thanks Matt.
@Gusten
Here's a script which works with my Hikvision DVR. I run three such scripts at 5 second intervals when the doorbell rings or when the side gate is opened, then send the images via iMessage.
import urllib2
import base64
img = "/<path to image folder>/snap1.jpg"
devIP = "<DVR IP address>"
username = "<DVR user name>"
password = "<DVR password>"
request = urllib2.Request("http://%s/PSIA/Streaming/channels/101/picture" % devIP)
base64string = base64.encodestring('%s:%s' % (username, password)).replace('\n', '')
request.add_header("Authorization", "Basic %s" % base64string)
buffer = urllib2.urlopen(request).read()
f = open(img, 'wb')
f.write(buffer)
f.close()
Mon Sep 11, 2017 11:56 pm
Gusten offline
Thanx, this wont work with my camera, mayby someone can help me
I have an Axis IP camera, and the download link for an snapshot is
http://192.168.213.238/jpg/image.jpg
So i tried this
import urllib2
import base64
devIP = "192.168.213.238"
username = "xxxxx"
password = "xxxxx"
request = urllib2.Request("http://%s/jpg/image.jpg" % devIP)
f = open(img, 'wb')
f.write(buffer)
f.close()
A get an HTTP Error 401: Unauthorized
if i change the path of the image to something wrong that do not exist i get
HTTP Error 404: Not found
so it seems like the script do go to the correct place, but is not able to log in?
If a use a browser, this way will work to se the image
http://username:password@192.168.213.238/jpg/image.jpg
Can anyone figure out why this is not working?
/Martin
Tue Sep 12, 2017 1:29 am
racarter offline
@Gusten
I guess the authorisation for Axis different to Hikvision.
Try something like:
base64.encodestring('%s:%s' % ('user', 'password'))[:-1]
Tue Sep 12, 2017 2:35 am
Gusten offline
Thanx, this didn't seems to work
  Script Error                    embedded script: invalid syntax
   Script Error                    around line 5 - "buffer = urllib2.urlopen(username:password@192.168.213.238/jpg/image.jpg).read()"
Tue Sep 12, 2017 3:46 am
racarter offline
Working blind here! I've edited the code, which should remove the syntax error.
Users browsing this forum: No registered users and 29 guests
