Receive Z-Wave Command and reset variable
Sat Aug 26, 2017 4:55 am
koburg offline
HI
Since im new yo photon I want to make this kind off script to reset a variable.
1. when the wave interface have not received any command from device in x sec then reset variable x
this is the command I want to check for.
0x01 0x0C 0x00 0x04 0x00 0x19 0x06 0x60 0x06 0x01 0x30 0x03 0xFF 0x43
I found this script in the wiki but how do I put it together to the z wave command instead. it is important that it is the code form above since the
z-wave device is not updating its status like normal in the UI
scipt from wiki:
from datetime import datetime
lamp = indigo.devices[91776575] # "Hallway light"
        indigo.device.turnOn(91776575)
Sat Aug 26, 2017 4:51 pm
Re: Receive Z-Wave Command and reset variable
Rather than scripting this, have a look at kmarklew's Timed Devices plugin.
It can do exactly what you want - we're using it for motion sensors whose batteries have died; if they don't update in 12 hours, they send me a message so I can go and check them.
Sat Aug 26, 2017 7:21 pm
kmarkley offline
Actually, the plugin isn't good for this since it only notices changes in device state, not heartbeat. But then again, this is a perfectly logical addition to the plugin (which I could use myself). I'll get something whipped up in a day or so.
Sun Aug 27, 2017 1:04 am
koburg offline
Thanks looking forward to .
Sun Aug 27, 2017 12:02 pm
kmarkley offline
Released. The plugin thread is here: viewtopic.php?f=134&t=18785
