Hi
I am using HTTPD plugin to report my weight from a Withing scale, and i get my weight in as a variable.
And i want to use this variable in a trigger as a condition "If variable is between xxx and xxx"
And this do not work, and i think its beacouse the variable is not an integer
Can this be and whats the easyest way to convert the variable to a integer? Or use this variable and convert to a new variable that i can use?
The variable is like this 85.81 so its all numbers with a dot and two decimals
Thanx
Martin
