Invalid Token
Sun Aug 06, 2017 8:14 pm
jltnol offline
Invalid Token
So I'm not the best at Python, but the following error came up and I'm not sure why..
If the SceneON is listed as
 indigo.insteon.sendSceneOn(7)
it won't run, but will if listed as
 indigo.insteon.sendSceneOn(07)
However this DOESN'T run
 indigo.insteon.sendSceneOn(08)
but
 indigo.insteon.sendSceneOn(8)
does.
The error I got was
Script Error embedded script: invalid token
Script Error around line 6 - "indigo.actionGroup.execute(1541175388),indigo.insteon.sendSceneOff(08)"
I'm not going to loose any sleep over this but was more curious as to why one has to be formatted WITH the preceding zero, and the other doesn't....
Any ideas ?
Sun Aug 06, 2017 8:24 pm
Re: Invalid Token
I don't think the prefix 0 is the problem. From the look of the error message, it looks like there might be a formatting problem with your script. It looks like Indigo doesn't think there is a line break between the action group execution line and the insteon sendSceneOff line?
Mon Aug 07, 2017 2:21 am
Re: Invalid Token
Another issue to be aware of is that in Python 2.7, a leading zero indicates an octal integer. So 07 is legal, 08 is not.
Wed Aug 09, 2017 6:40 pm
jltnol offline
Re: Invalid Token
FWIW, I actually just coped the 1st line and pasted into the "else:" option, and changed the scene # to 08, and got the same error message... changing it from "08" to just "8" makes the error message go away... Likewise, changing the 1st line from "07" to "08" introduced the same error message... but going to just "8" made it go away.
dev = indigo.devices[120542152] # "KeypadLinc"
if (dev.ledStates[2] == True):
   indigo.actionGroup.execute(339158514), indigo.insteon.sendSceneOn(07)
   indigo.actionGroup.execute(339158514), indigo.insteon.sendSceneOn(08
Thu Aug 10, 2017 9:05 am
Re: Invalid Token
It's the octal specifier mentioned by FlyingDiver above. Literals that start with a zero are interpreted as octal values and 08 is an invalid octal number.
Thu Aug 10, 2017 9:07 am
Re: Invalid Token
Note that this is Python 2.x only. Which Indigo uses. Python 3 requires the use of the "0o" or "0O" prefix (zero-Oh).
Thu Aug 10, 2017 2:09 pm
Re: Invalid Token
IMO, it was a terrible idea in Python 2.x to do that. The Python 3 way is much better.
Unfortunately, I believe it's still in Python 3 for backwards compatibility... :(
Thu Aug 10, 2017 2:10 pm
Re: Invalid Token
Other way around, I think. 2 would take either, 3 will only take "0o". The leading zero was a nod towards a number of other languages which do the same thing. I think it started with C.
Sun Aug 13, 2017 10:49 am
jltnol offline
Re: Invalid Token
From a non-coder point of view, I do find it amusing that sometimes the simplest things are complicated... In the end, this was an easy hurdle for me to get over as I knew that the code worked in some instances. Past that, it was just a matter of experimenting 'til I came up with the right answer, and there were only 2 options... , but can easily understand that others my find this maddening..
