Help with very simple script
Thu May 25, 2017 1:58 pm
PhilP offline
I’m new to the world of scripting and could do with a pointer. Despite searching i’m still unsure of the correct syntax. Not even sure if i’m supposed to be using Python or Applescript?
I know this is incredibly simple script. Basically I want a script to check if a device is On, if so switch it off. I will then repeat this for multiple devices. It’s to be actioned from a trigger so I don’t have to create a separate trigger with condition and action for each device.
Thanks for your help
Thu May 25, 2017 4:32 pm
Re: Help with very simple script
Python is the way forward here.
But - can you explain your scenario?
If you're only testing if a device is on, then turning it off if it is, then don't bother testing it at all; just turn it off anyway - it'll turn off if it's on, or stay off if it isn't.
That can be done without scripting all together - in your trigger just add several turnoff commands via the UI.
Fri May 26, 2017 2:35 am
PhilP offline
I presumed it would be more efficient to only send commands if necessary, hence checking if the device was on before sending an off.
Building on this I am wanting to reduce the number of triggers by nesting multiple commands in scripts.
I also want to (for some devices) only send and on/off if it falls within a certain time range.
Sat May 27, 2017 4:04 am
sgbirch offline
I have something similar to run my central heating. My system has to "notice" when a family member turns the heat up in one of the rooms. Usually, they feel cold if the heating hasn't been on for long and the walls are still cooler than the room which causes convection currents. So, if they turn it up the system waits at the higher temperature for an hour and then resets it to 21c.
Since there are about 15 rooms I chose to use a python script so every change to the system doesn't have to be repeated 15 times. Here is how it works:
1. The script is called every 5 seconds.
2. Devices are identified by the script using special names (e.g. roomname_radiator)
3. The script has no state information so variables are used (roomname_triggered)
The script was then put in
Sat May 27, 2017 4:05 pm
PhilP offline
Anyone got some example code I can use as a starter?
Sat May 27, 2017 7:48 pm
Here is a very simple script which checks to see if a light is on, and if it is, turn it off.
dev = indigo.devices[1990777234]
if dev.onState:
   indigo.device.turnOff(1990777234)
Sun May 28, 2017 11:43 am
PhilP offline
Thanks for the example. Looks straightforward.
How would I add a condition for a time window?
e.g. Check if device is on AND current time between 18:00 and 21:00 hours then switch device off
Sun May 28, 2017 2:22 pm
In Python, there's often several different ways to do the same thing--I think this is a nice example that's pretty straightforward.
import datetime
now = datetime.datetime.now()
time_1 = now.replace(hour=18, minute=0, second=0, microsecond=0)
time_2 = now.replace(hour=21, minute=0, second=0, microsecond=0)
if dev.onState and (time_1 <= now <= time_2):
Mon May 29, 2017 3:34 am
I like that use of time replacement!
Don't know if it exists in Python but I've always used mktime() in php - I prefer your method though!
Mon May 29, 2017 12:27 pm
PhilP offline
Thanks. Plenty to get me started.
Is there an online reference for the commands and syntax?
Mon May 29, 2017 12:44 pm
Do a search for 'python datetime'. The official Python docs are a little tough to follow if you're not that familiar with Python, but there are many good examples on other sites. Look especially at http://stackoverflow.com where the common practice is to explain *why* a particular approach is used.
