Starting out with Python
Fri Apr 21, 2017 9:47 am
Re: Starting out with Python
Inspecting devices in a Scripting Shell is really going to help you here - it's much more interactive than trying to write stuff to the log. You can print a device in the shell and it will show you everything there is to know about a device.
For instance, once you have a shell window open (this is a WeatherSnoop device which is quite involved):
>>> dev = indigo.devices[1234567890] # "KATT Agent in WeatherSnoop"
>>> print unicode(dev)
address : FatBook.local.:7999
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : ws3station
displayStateId : temperature_F
displayStateImageSel : TemperatureSensor
displayStateValRaw : 88.0
displayStateValUi : 88.0 °F
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1605027967
     com.perceptiveautomation.indigoplugin.weathersnoop : (dict)
          address : FatBook.local.:7999 (string)
          displayState : temperature_F (string)
          dynamicStates : (list)
               [SNIP for brevity]
          host : localhost (string)
          manual : false (bool)
          port : 8000 (string)
          siteName :  (string)
          wsAgent : http://FatBook.local.:7999/2DFAB35B-B074-4F7F-835A-B4EB2BEDAF6F.json (string)
          wsInstance : WeatherSnoop 3 - FatBook@FatBook.local.:7999 (string)
     emptyDict : (dict)
lastChanged : 2017-02-02 16:32:26
lastSuccessfulComm : 2017-02-02 16:32:26
model : WeatherSnoop 3 Agent
name : KATT Agent in WeatherSnoop
ownerProps : com.perceptiveautomation.indigoplugin.weathersnoop : (dict)
          [SNIP for brevity]
     siteName :  (string)
pluginId : com.perceptiveautomation.indigoplugin.weathersnoop
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     agent : Weather Underground (string)
     agent.ui : Weather Underground (string)
     barometricTrend : Steady (string)
     barometricTrend.ui : Steady (string)
     dayRain_cm : -9999.00 (real)
     dayRain_cm.ui : -9999.0 cm (string)
     dayRain_in : -9999.00 (real)
     dayRain_in.ui : -9999.0 in (string)
     dayRain_km : -9999.00 (real)
     dayRain_km.ui : -9999.0 km (string)
     dayRain_mi : -9999.00 (real)
     dayRain_mi.ui : -9999.0 mi (string)
     dayRain_mm : -9999.00 (real)
     dayRain_mm.ui : -9999.0 mm (string)
     dewPoint_C : 22.20 (real)
     dewPoint_C.ui : 22.2 °C (string)
     dewPoint_F : 72.00 (real)
     dewPoint_F.ui : 72.0 °F (string)
     elevation : -9999 ft (string)
     elevation.ui : -9999 ft (string)
     heatIndex_C : 34.40 (real)
     heatIndex_C.ui : 34.4 °C (string)
     heatIndex_F : 94.00 (real)
     heatIndex_F.ui : 94.0 °F (string)
     humidity : 59 (integer)
     humidity.ui : 59% (string)
     latitude : 30.507950 (string)
     latitude.ui : 30.507950 (string)
     location.ui : Somewhere else (string)
     longitude : -97.887871 (string)
     longitude.ui : -97.887871 (string)
     name : Station KOPEL (string)
     name.ui : Station KOPEL (string)
     rainOneHour_cm : 0.00 (real)
     rainOneHour_cm.ui : 0.0 cm (string)
     rainOneHour_in : 0.00 (real)
     rainOneHour_in.ui : 0.0 in (string)
     rainOneHour_km : 0.00 (real)
     rainOneHour_km.ui : 0.0 km (string)
     rainOneHour_mi : 0.00 (real)
     rainOneHour_mi.ui : 0.0 mi (string)
     rainOneHour_mm : 0.00 (real)
     rainOneHour_mm.ui : 0.0 mm (string)
     relativeBarometricPressure_cb : 102 (integer)
     relativeBarometricPressure_cb.ui : 102 cb (string)
     relativeBarometricPressure_inHg : 30.10 (real)
     relativeBarometricPressure_inHg.ui : 30.1 inHg (string)
     relativeBarometricPressure_mb : 1019 (integer)
     relativeBarometricPressure_mb.ui : 1019 mb (string)
     solarRadiation : 455 (integer)
     solarRadiation.ui : 455 wm2 (string)
     temperature_C : 31.10 (real)
     temperature_C.ui : 31.1 °C (string)
     temperature_F : 88.00 (real)
     temperature_F.ui : 88.0 °F (string)
     uri : /2DFAB35B-B074-4F7F-835A-B4EB2BEDAF6F.json (string)
     uri.ui : /2DFAB35B-B074-4F7F-835A-B4EB2BEDAF6F.json (string)
     uvIndex : 3.00 (real)
     uvIndex.ui : 3.0 (string)
     version : 3.1.7 (1116) (string)
     version.ui : 3.1.7 (1116) (string)
     visibility_cm : 1609337.10 (real)
     visibility_cm.ui : 1609337.1 cm (string)
     visibility_in : 633598.86 (real)
     visibility_in.ui : 633598.86 in (string)
     visibility_km : 16.10 (real)
     visibility_km.ui : 16.1 km (string)
     visibility_mi : 10.00 (real)
     visibility_mi.ui : 10.0 mi (string)
     visibility_mm : 16093411.10 (real)
     visibility_mm.ui : 16093411.1 mm (string)
     weather : Mostly Cloudy (string)
     weather.ui : Mostly Cloudy (string)
     windChill_C : 6.70 (real)
     windChill_C.ui : 6.7 °C (string)
     windChill_F : 44.00 (real)
     windChill_F.ui : 44.0 °F (string)
     windDirection : 80 (integer)
     windDirection.ui : 80° (E) (string)
     windGust_kn : 0.00 (real)
     windGust_kn.ui : 0.0 kn (string)
     windGust_kph : 0.00 (real)
     windGust_kph.ui : 0.0 kph (string)
     windGust_mph : 0.00 (real)
     windGust_mph.ui : 0.0 mph (string)
     windGust_mps : 0.00 (real)
     windGust_mps.ui : 0.0 mps (string)
     windSpeed_kn : 3.50 (real)
     windSpeed_kn.ui : 3.5 kn (string)
     windSpeed_kph : 6.40 (real)
     windSpeed_kph.ui : 6.4 kph (string)
     windSpeed_mph : 4.00 (real)
     windSpeed_mph.ui : 4.0 mph (string)
     windSpeed_mps : 1.80 (real)
     windSpeed_mps.ui : 1.8 mps (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Fri Apr 21, 2017 10:11 am
BlaineM offline
Indeed, much easier. Thank you.
--Blaine
Sun Aug 05, 2018 3:36 pm
hamw offline
Could someone help me convert this snippet to Python? I use it to check the state of my garage door autoclose to make sure it did in fact close. It checks to see if the garage door is open (I/O Linc binary outputs are true) and the variable GarageAutoClose is also true, and if both true then activates the I/O linc named "aGarageDoor1." Note that I set GarageAutoClose true or false to prevent the autoclose from happening if working in the garage, for instance.
      if ((value of variable "Garage1" is "true") and (value of variable "GarageAutoClose" is "true")) then
         set binary outputs of device "aGarage Door 1" to {true}
      end if
   end tell
   delay 60
      end if
   end tell
I think it would begin with something like this, but don't know how to assemble the state query and then the if/then statement:
GarageDoor1 = indigo.devices["GarageDoor1"]
if hasattr(iolinc, 'onState'):
   isOn = iolinc.onState
GarageAutocloseVar = indigo.variables[123]
then what??
Mon Aug 06, 2018 4:41 am
I think this is a literal conversion of your AppleScript:
from time import sleep
Garage1 = indigo.variables['Garage1'].value  # It's recommended to use Indigo ID numbers instead of names, but names will work.
GarageAutoClose = indigo.variables['GarageAutoClose'].value
if Garage1 == 'true' and GarageAutoClose == 'true':
    indigo.iodevice.setBinaryOutput('Garage1', 0, True)
sleep(60)
Mon Aug 13, 2018 8:53 pm
hamw offline
Dave,
First, thanks so much for your assistance. i read over the prior posts and your explanations are very helpful and appreciated. I gave your script a try, incorporating the device attributes query so that I could get the list available on an IOLinc. I used binary.input to get the current state of open/closed, but it won't log, and thus I think it may not run. Ideas?
device_id = 308749424
dev = indigo.devices[device_id]
#dev = indigo.devices[308749424]
#indigo.server.log(unicode(dev)) #gets all possible states of device
Garage1 = indigo.devices[308749424].binaryInputs  <<<<<<<<<<<<< gets past this part
GarageAutoClose = indigo.variables[1770515678].value
indigo.server.log(GarageAutoClose)
indigo.server.log(Garage1)   <<<<<<<<<< won't log and fails here.
Tue Aug 14, 2018 5:53 am
You are very close! Indigo will only log strings, so any value that's not a string will need to be converted. I've simplified the script a bit to make it easier to see what's going on. In addition to changing the log command which results in the error, I've also changed the script slightly because I think the 'binaryInputs' property of the device is likely already a boolean value (True, False). I can't test this, so you'll have to let me know if it works the way you want.
Garage1 = indigo.devices[308749424].binaryInputs  # <<<<< This value is likely not a string.
indigo.server.log(u"{0}".format(Garage1))  # <<<<< I prefer the format() command for logging which handles the conversion.
indigo.server.log(u"{0}".format(GarageAutoClose))
if Garage1 and GarageAutoClose == 'true':
    indigo.iodevice.setBinaryOutput(308749424, 0, True)
I'm a bit unsure about the last line, which appears to set the binary input of device 308749424 (Garage1) to True when its value is already True (and the value of GarageAutoClose is 'true'). Let's make sure this runs without error and then we can change the logic if we need to.
Tue Aug 14, 2018 8:51 pm
hamw offline
Success! That single script incorporates a lot of what I need in my system... comparing values, executing an action and logging to be sure the action s actually done. That will make it a lot easier to transition to Python. Thanks very much for your help!
Wed Aug 15, 2018 6:06 am
Glad to hear that worked for you. A note about the 'if' statement and boolean testing. The first bit:
if Garage1...
Garage1 is either True or False and Python will only evaluate the second bit if the first bit is True. Note that True (a boolean) is not the same as 'true' (a string) even though they both evaluate to True.
It's easiest to see with this example:
>>> if 'false':
...     print('True')
True
In other words, the string 'false' evaluates to True. Examples of things that are False:
  • False
  • 0 (zero)
You may understand all this already, but it starts to get tricky when we get creative:
if a != 'true' and (b or c) not d and e:
Feel free to ping back with any questions!
Wed Aug 15, 2018 8:53 am
  • False
  • 0 (zero)
And in most circumstances, None (I'm ignoring the esoterica of the None object).
One other trick: if you have an Indigo variable that's a boolean, then you can explicitly get the value as a boolean, which makes those kinds of comparisons even easier. Here's a slightly altered version of the script:
GarageAutoClose = indigo.variables[1770515678].getValue(bool)
if Garage1 and GarageAutoClose:
So you use the getValue() method on the variable object and specify the type of the value you want returned. You can also use int and float.
Sun Aug 19, 2018 9:07 pm
hamw offline
This seems like it should work... but instead of bypassing the action when the script is not true, it executes anyway. I tried adding a variable as a test, thinking that the IO Linc might not be responding fast enough, but same result.It keeps executing the IO Linc and will open the garage door if closed. Thoughts?
Schedule                        Garage Door 1 Auto Close (delayed action)
   Script                          [False]
   Script                          false
   Script                          true
   Sent INSTEON                    "aGarage Door 1" on
   Received INSTEON                "aGarage Door 1" on
   Sent INSTEON                    "aGarage Door 1" status request (received input sensor: open)
   Sent INSTEON                    "aGarage Door 1" status request (received output relay: off)
The current script:
Garage1_State = indigo.variables[552843942].value
indigo.server.log(u"{0}".format(Garage1_State))
if Garage1_State and GarageAutoClose == 'true':
Mon Aug 20, 2018 5:36 am
   Script                          [False]
   Script                          false
   Script                          true
The current script:
Based on your output, it looks like the value of Garage1 is a list (and not a binary value), so it seems that we'll need to access the list element instead. This is untested, but I think it just might work:
Garage1 = indigo.devices[308749424].binaryInputs[0]  # <<<<< We are attempting to access the 'zeroth' element of the list (the index of the first item is zero).
EDIT: Only an empty list would evaluate to False.
Mon Aug 20, 2018 6:13 am
hamw offline
I tried to take the IO link out of the process completely by referencing the variable “garage1”. That variable is set by an indigo action according to the current state of the IOLinc before the script is executed and so represents the current state of the garage IOLinc input. Thus the comparison is currently between the variable “garage1” and the variable “garage auto close.” I would have thought that if the syntax was correct in the comparison it would have resolved to “false, true “ . Since both are not true I would have thought it would pass through the comparison without executing the action.
So could there be a syntax problem in the comparison statement?
Mon Aug 20, 2018 8:07 am
Maybe. I can never remember the precedence order. Try this:
if Garage1_State and (GarageAutoClose == 'true'):
Mon Aug 20, 2018 8:52 am
If I'm understanding your example, any non-empty Indigo variable would evaluate to True regardless of its contents unless you use Jay's suggestion to 'getValue()'. In other words, a variable value of 'false' or 'False' would evaluate as True. A variable set to 'false' yields:
val = indigo.variables[60344867]
if val:
    indigo.server.log('True')
    indigo.server.log('False')
# Yields 'True'
val = indigo.variables[60344867].getValue(bool)
if val:
# Yields 'False'
Tue Aug 21, 2018 2:32 pm
This:
will always have "if val:" evaluate as True because it isn't the value of the variable. It is the python instance object that represents the entire variable object in Indigo (including the name, value, and other properties). You can use either val.value to extract the value as a string (which will evaluate to True if the string length is > 0; that is, not empty) or you can extract out a specific type of value using the var.getValue(_some_type_) method.
