Garage Door Open after "x" time script - help needed
Thu Feb 02, 2017 7:33 am
guitarfreak offline
I'm VERY new to scripting and just trying to figure it out as I go. I followed the topic on creating a script to send me an e-mail and text if the garage door is open after "x" amount of time. However, the script is sending the notification regardless of if the door is open or not, so I'm sure I messed something up, but I'm not sure what?
I am using the newer version of the i/o linc and from the screenshot of the device, you can see it does show binary input 1 as "closed" when the door is closed.
Screenshots attached.
Thanks in advance for the help, I'm sure this will be a quick fix for someone else.
Screenshot 2017-02-02 07.32.03.png (180.32 KiB) Viewed 1578 times
Screenshot 2017-02-02 07.28.17.png (66.53 KiB) Viewed 1578 times
Screenshot 2017-02-02 07.21.41.png (116.32 KiB) Viewed 1578 times
Thu Feb 02, 2017 4:33 pm
rycardo offline
Re: Garage Door Open after "x" time script - help needed
Can you do it without scripting? Add delayed actions that sends your alerts, but then when the door closes, create a trigger that cancels the delayed actions. It's in action menu somewhere, I'm away from home so can't say for what.
Fri Feb 03, 2017 6:51 am
guitarfreak offline
That's a good idea and simpler than what I'm doing! I'll try it
Fri Feb 03, 2017 1:02 pm
Or you could start a timer when it goes up, then check if it's down in the timer action.
Fri Jun 02, 2017 7:03 pm
mikeL offline
There's an error in your python script. The line containing the function indigo.server.sendEmailTo() needs to be indented (tabbed) to make it part of the proceeding if statement. Otherwise, as you noted, email will always be sent.
