Newbie python scripting question
Wed Feb 01, 2017 9:15 am
aderrington offline
I'm trying to create an Internet speed test script that will run and report the download speed to a variable, the variable would be watched by a charting plugin and would then graph the speed throughout the day (the script would run every hour)
My script so far is:
import requests
url = 'http://ipv4.download.thinkbroadband.com/100MB.zip'
requests.get(url)
This downloads a 100Mb file. How can i run this and get the result? I can run it in terminal and it works fine, (i installed wget etc to get it to work)
Any thoughts?
Thanks in advance.
Andrew
EDIT -
Sorry, just realised that the command i was actually running in terminal is:
wget -0 /dev/null http://ipv4.download.thinkbroadband.com/100MB.zip
But i cut it down to get it to run in Python, But i don't get any feedback once it's complete.
Wed Feb 01, 2017 9:17 am
Re: Newbie python scripting question
What do you mean by "get the result"? Do you mean save the file? Or record the time it takes to download the file?
Wed Feb 01, 2017 9:20 am
aderrington offline
In terminal it gives a transfer speed
2017-02-01 14:50:55 (11.8 MB/s) - ‘/dev/null’ saved [104857600/104857600]
It's the transfer speed that i'm after.
Thanks.
Wed Feb 01, 2017 9:30 am
That's wget reporting the transfer speed, so using requests to transfer the file isn't going to do anything useful.
You could run wget in a subprocess and parse the result string to get that number.
Or, if it was me, I'd use speedtest-cli.
sudo pip install speedtest-cli
import speedtest
s = speedtest.Speedtest()
s.get_best_server()
s.download()
results = s.results.dict()
download  = results["download"]
See https://github.com/sivel/speedtest-cli for more info.
Shamu:~ jkeenan$ python
Python 2.7.10 (default, Jul 30 2016, 19:40:32)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import speedtest
>>> s.get_best_server()
{'latency': 17.969, 'name': 'Bonita Springs, FL', 'url': 'http://stosat-bspr-01.sys.comcast.net/speedtest/upload.php', 'country': 'United States', 'lon': '-81.7387', 'cc': 'US', 'host': 'stosat-bspr-01.sys.comcast.net:8080', 'sponsor': 'Comcast', 'url2': 'http://a-stosat-bspr-01.sys.comcast.net/speedtest/upload.php', 'lat': '26.3548', 'id': '8087', 'd': 36.117175127976374}
>>> s.download()
85160228.89793384
>>> s.upload()
11419778.686360242
>>> print s.results.dict()
{'download': 85160228.89793384, 'timestamp': '2017-02-01T15:26:43.100689', 'ping': 17.969, 'upload': 11419778.686360242, 'server': {'latency': 17.969, 'name': 'Bonita Springs, FL', 'url': 'http://stosat-bspr-01.sys.comcast.net/speedtest/upload.php', 'country': 'United States', 'lon': '-81.7387', 'cc': 'US', 'host': 'stosat-bspr-01.sys.comcast.net:8080', 'sponsor': 'Comcast', 'url2': 'http://a-stosat-bspr-01.sys.comcast.net/speedtest/upload.php', 'lat': '26.3548', 'id': '8087', 'd': 36.117175127976374}}
Wed Feb 01, 2017 9:55 am
aderrington offline
Ok. Thanks for that. I'll give that a go later when i get home.
Thank you.
Thu Feb 02, 2017 4:42 pm
aderrington offline
Thanks for your suggestions, I've got it all working nicely now.
Thank you.
Andrew
Thu Feb 02, 2017 4:52 pm
Glad to hear. That looks pretty useful, so I think I'll probably wrap it in a plugin.
Thu Feb 02, 2017 4:53 pm
aderrington offline
That would be great. I've got it currently as a schedule running every 30 mins.
Thu Feb 02, 2017 5:26 pm
kmarkley offline
This sounds like a very logical addition to my Online Sensor plugin. I will add it this weekend.
Sat Feb 04, 2017 1:32 pm
kmarkley offline
Speedtest devices are now included in my Online Sensor plugin.
I hope you find it useful.
