Determining the class of a device
Sat Jan 07, 2017 9:58 am
kmarkley offline
I'm sure this is easy, but I can't seem to find it in the wiki.
I know I can get devices of a particular class:
indigo.devices.iter(filter="indigo.relay")
But if I already have a device instance, how do I determine if it's the kind I'm interested in?:
def deviceUpdated(self, oldDev, newDev):
    if ???newDev is indigo.relay???:
        do stuff
Sat Jan 07, 2017 10:06 am
kmarkley offline
Re: Determining the class of a device
D'oh:
type(newDev)
I need more coffee.
Sat Jan 07, 2017 11:59 am
It depends on what you are doing, but I most often end up using isinstance:
            if isinstance(dev, indigo.DimmerDevice):     # or indigo.RelayDevice, indigo.ThermostatDevice, etc.
Note that dimmer is a subclass of relay, so if you check for indigo.DimmerDevice then it will return true for all dimmers and relays.
Sat Jan 07, 2017 2:09 pm
kmarkley offline
Even better. Thank you.
