Script to increment variable with timing?
Thu Jul 27, 2017 6:12 pm
Re: Script to increment variable with timing?
Different Computers wrote:
How can I round it off in the script? I'm starting to research this, but I worry about breaking the script.
If it doesn't want any decimal places, just convert it to an integer:
# Calculate the new value originally set at darknessValue = (sourceDevice.sensorValue-1000) * -0.1
darknessValue = int((sourceDevice.sensorValue-1000) * -0.1)
# Set the value of the destination variable
indigo.variable.updateValue(1021324478, value=str(darknessValue))
Thu Jul 27, 2017 6:48 pm
Different Computers offline
Perfect!!
Thank you.
Mon Jul 31, 2017 8:47 pm
What in the world am I missing??
Luminance reading = 1.04% This is sourceDevice.sensorValue.
Python code: darknessValue = int((sourceDevice.sensorValue-1000) * -0.1)
1.04 -1000 x -0.1 = 99.896
My darkness variable (which is derived from the python code above) equals 94
Tue Aug 01, 2017 5:09 am
I'm not sure. When I run your code, I get 99. If my math is right, you need a sensorValue of around 60 to arrive at 94.
Also, I'd suggest doing the following which would be a little bit more precise:
r_val = round((sourceDevice.sensorValue-1000) * -0.1)
i_val = int(r_val)
