- Code: Select all
indigo.variable.updateValue(269281850)
Thank you
indigo.variable.updateValue(269281850, "asleep")
# indigo.variable.updateValue(1568794432, value = str("Vacant"))
True will be returned if the value is one of these: “true”, “on”, “yes”, and “1”. False will be returned if the value is one of these: “false”, “off”, “no”, and “0”. If no default value is specified and the value can't be successfully converted, the method will return False.
