Remote access issue to new Web Server on 2022.2
Sat Feb 25, 2023 7:49 pm
TimH offline
I can log into the web server (note I override the port to 8081) on the local machine using the LAN IP address and user name and password.
If I do the same from a remote IP, I get an access error and the pages gets stuck "LOADING..."
Is there some config for the new web server to allow remote connections? I don't use reflector.
Indigo Touch works as expected with the same IP address and user/password.
Feb 26, 2023 at 1:35:10 AM
Web Server Warning access denied for request /v2/api/ws/log-feed from 47.152.254.203
Web Server Warning access denied for request /v2/api/ws/action-feed from 47.152.254.203
Web Server Warning access denied for request /v2/api/ws/device-feed from 47.152.254.203
Web Server Warning access denied for request /v2/api/ws/page-feed from 47.152.254.203
Web Server Warning access denied for request /v2/api/ws/variable-feed from 47.152.254.203
Sun Feb 26, 2023 2:37 pm
Re: Remote access issue to new Web Server on 2022.2
Are you using a proxy server to route the traffic to Indigo's web server (for HTTPS access maybe)? If so it needs to be configured to allow websockets.
Sun Feb 26, 2023 5:21 pm
TimH offline
No, proxy. I am using port forwarding from the public address to the Mac mini Indigo runs on, but it just maps 8081 to 8081 on the server and it's working as it clearly sees the request to refuse it. As I mentioned, I am using 8081 as an override in the web server start up dialog.
Sun Feb 26, 2023 6:01 pm
Are you prompted for authentication by the browser?
Try restarting the browser, and clearing any cookies related to that IP address. Also try a different browser to see if it is browser specific.
Mon Feb 27, 2023 10:06 am
jltnol offline
Hey Matt
I'm having similar issues with web browsers. I'm using Safari as my main browser, but also have Brave installed as well. I've got a FQDN that points to the IP address at home, and my router has port 8176(changed from default) forwarded to the LAN ip address of my Indigo Server. Prior to this update, everything worked fine, and I could access the Indigo web server by 2 methods:
192.168.6.102:8176 ( this goes to the ip address of my Indigo server, and this method works fine across all browsers)
The other method is mydomainname.com:8176, and this one does NOT work on any browsers. I've emptied the cache, cleared the cookies, but when I try to go to the server, I am asked for user and PW info, fill that out then get to the pic below and it stops. I've even downloaded a new browser, Vivaldi, and have the same issue. I can get to the server on the LAN, just not thru my domain name.
Are more ports needed now for web access? I can PM you my info if you like.
Screenshot 2023-02-27 at 9.51.46 AM.png (33.38 KiB) Viewed 2835 times
Mon Feb 27, 2023 10:23 am
Can you open the JavaScript console in Safari and reload the page to see what if any errors you see written to the console log?
Mon Feb 27, 2023 10:34 am
jltnol offline
So I'm going to paste the whole Java stuff... got no idea what any of it means BUT... I CAN access the server thru the Reflector. Don't know if that helps much, but at the very least, it is a solution I can use. Java log below:
[Info] 2023-02-27T10:31:57.902Z   INFO   websocket url base: ws://jlthla.com:8176 (index.js, line 62)
[Info] 2023-02-27T10:31:57.934Z   INFO   Opening websocket for indigo.Device instances at: ws://jlthla.com:8176/v2/api/ws/device-feed (index.js, line 62)
[Info] 2023-02-27T10:31:57.935Z   INFO   Opening websocket for indigo.ActionGroup instances at: ws://jlthla.com:8176/v2/api/ws/action-feed (index.js, line 62)
[Info] 2023-02-27T10:31:57.935Z   INFO   Opening websocket for indigo.Variable instances at: ws://jlthla.com:8176/v2/api/ws/variable-feed (index.js, line 62)
[Info] 2023-02-27T10:31:57.935Z   INFO   Opening websocket for indigo.ControlPage instances at: ws://jlthla.com:8176/v2/api/ws/page-feed (index.js, line 62)
[Info] 2023-02-27T10:31:57.936Z   INFO   Opening log websocket at: ws://jlthla.com:8176/v2/api/ws/log-feed (index.js, line 62)
[Info] 2023-02-27T10:31:57.963Z   INFO   'device' websocket opened (index.js, line 62)
[Info] 2023-02-27T10:31:57.982Z   INFO   'action' websocket opened (index.js, line 62)
[Info] 2023-02-27T10:31:57.983Z   INFO   'page' websocket opened (index.js, line 62)
[Info] 2023-02-27T10:31:57.983Z   INFO   'variable' websocket opened (index.js, line 62)
[Error] WebSocket connection to 'ws://jlthla.com:8176/v2/api/ws/device-feed' failed: The operation couldn’t be completed. (kNWErrorDomainPOSIX error 100 - Protocol error)
[Error] 2023-02-27T10:31:57.991Z   ERROR   'device' websocket error:
   Ce (index.js:62:124771)
   Yl (index.js:67:14093)
   Yl
[Error] 2023-02-27T10:31:57.991Z   ERROR   {"isTrusted":true}
   Yl (index.js:67:14146)
   Yl
[Warning] 2023-02-27T10:31:57.991Z   WARNING   'device' websocket closed (index.js, line 62)
[Error] WebSocket connection to 'ws://jlthla.com:8176/v2/api/ws/variable-feed' failed: The operation couldn’t be completed. (kNWErrorDomainPOSIX error 100 - Protocol error)
[Error] 2023-02-27T10:31:58.003Z   ERROR   'variable' websocket error:
   Yl
[Error] 2023-02-27T10:31:58.003Z   ERROR   {"isTrusted":true}
   Yl
[Warning] 2023-02-27T10:31:58.003Z   WARNING   'variable' websocket closed (index.js, line 62)
[Error] WebSocket connection to 'ws://jlthla.com:8176/v2/api/ws/log-feed' failed: The operation couldn’t be completed. (kNWErrorDomainPOSIX error 100 - Protocol error)
[Error] 2023-02-27T10:31:58.026Z   ERROR   2023-02-27T10:31:58.026Z   WEBSOCKET error:
   (anonymous function) (index.js:141:14331)
[Error] 2023-02-27T10:31:58.026Z   ERROR   {"isTrusted":true}
   (anonymous function) (index.js:141:14367)
[Info] 2023-02-27T10:31:58.026Z   INFO   2023-02-27T10:31:58.026Z   WEBSOCKET closed (index.js, line 62)
[Error] WebSocket connection to 'ws://jlthla.com:8176/v2/api/ws/page-feed' failed: The operation couldn’t be completed. (kNWErrorDomainPOSIX error 100 - Protocol error)
[Error] 2023-02-27T10:31:58.057Z   ERROR   'page' websocket error:
   Yl
[Error] 2023-02-27T10:31:58.057Z   ERROR   {"isTrusted":true}
   Yl
[Warning] 2023-02-27T10:31:58.057Z   WARNING   'page' websocket closed (index.js, line 62)
[Error] WebSocket connection to 'ws://jlthla.com:8176/v2/api/ws/action-feed' failed: The operation couldn’t be completed. (kNWErrorDomainPOSIX error 100 - Protocol error)
[Error] 2023-02-27T10:31:58.091Z   ERROR   'action' websocket error:
   Yl
[Error] 2023-02-27T10:31:58.091Z   ERROR   {"isTrusted":true}
   Yl
[Warning] 2023-02-27T10:31:58.091Z   WARNING   'action' websocket closed (index.js, line 62)
Mon Feb 27, 2023 11:06 am
Can you turn on Indigo's web server debug logging checkbox (inside main Prefs dialog, General panel), and try the connection again? Copy/paste the Event Log window results so we can see what the server side is doing.
Mon Feb 27, 2023 11:25 am
jltnol offline
Matt
Here you go.
there are a whole bunch of "authenticate password -- access denied" lines of code as soon as I hit enter in the browsers before I 'm asked for credentials... but I suspect you are more interested in the api lines of code:
 Web Server Warning              access denied for request /index.html from 209.205.130.31 (user indigo)
   Web Server Debug                authenticate password failed to match"
   Web Server Debug                Queue 'patch' message for a 'indigo.Device'
   Web Server Warning              access denied for request /web/js/index.js from 209.205.130.31 (user indigo)
   Web Server Warning              access denied for request /web/css/index.css from 209.205.130.31 (user indigo)
   Web Server Warning              access denied for request /v2/api/ws/device-feed from 209.205.130.31
   Web Server Warning              access denied for request /v2/api/ws/action-feed from 209.205.130.31
   Web Server Warning              access denied for request /v2/api/ws/variable-feed from 209.205.130.31
   Web Server Warning              access denied for request /v2/api/ws/page-feed from 209.205.130.31
   Web Server Warning              access denied for request /v2/api/ws/log-feed from 209.205.130.31
   Airfoil Pro Warning             Trying to restart airfoil device 'AF-K-100 Kitchen Airfoil Music' - will continue to try silently
   Airfoil Pro Warning             Trying to restart airfoil device 'AF-S-200 Studio Airfoil Music' - will continue to try silently
Mon Feb 27, 2023 11:29 am
Can you try it again in an incognito/private browsing window so that it doesn't use saved credentials or cookies?
Mon Feb 27, 2023 11:40 am
jltnol offline
Ok so I went to a Private Window in Safari, go to my URL, asked for username and PW, but still get the same set of error messages in the web log, and end up with the "Loading" page.
Also changed the port in Indigo, to force entering credentials again, but still have the same results. Log in seems successful, but I end up at the "Loading" page...
And Reflector access continues to work as designed.
Mon Feb 27, 2023 4:38 pm
jltnol offline
and not sure if this helps or not, but I use Locative for GPS enter/exiting triggers. They use the Reflector, not my personal URL, and they are not workin now either.
Mon Feb 27, 2023 7:22 pm
I think that is an unrelated issue. If it is using the old RESTful API, then it needs to be updated to the new API. See the blog announcement (about mid-way down) for a discussion and some links that might help.
Tue Feb 28, 2023 3:22 pm
TimH offline
Matt, please also note that you potentially are logging a lot of data (with Debug not enabled) in /Library/Application Support/Perceptive Automation/Indigo 2022.2/Logs/indigoplugin.webserver/plugin.log. Every time a variable changes you are logging the before and after values. If someone has a really big variable they are using and it changes frequently, it will fill their disk pretty quickly. Yes, I had a daily temperature list that that was missing code to reset it each day - impressive that Indigo can handle a 15MB variable ;-)
Wed Apr 19, 2023 2:04 pm
jltnol offline
So FYI, this issue still persists.
I still can't access the Indigo Web Pages using
http://mydomain.com:8177
But can using
http://myreflector.indigodomo.net
As I recall, this stopped working with the 2022.1 update and continues into the 2022.2 update. Kind of an easy work-around but am still curious why this doesn't work, anymore. The domain points to my home IP address and port 8177 is forwarded to the Indigo Server on my LAN on my router. Is it possible the web server has been moved to a different port?
