Dark Mode missing on client
Tue Feb 11, 2020 3:40 pm
P15-D24 offline
On my Mac Mini Indigo runs in dark mode. That is where the server is. When I connect to it from my MBP Indigo is in light mode, even though dark mode is selected in appearance. Config error or bug? Version is 7.4 for client, 7.4.1 for server. Both machines run 10.15.3
Running OS X 12.2.1 on 2018 Mac Mini, Indigo 2022.2
http://www.p15-d24.com
Tue Feb 11, 2020 3:42 pm
Re: Dark Mode missing on client
You have to download and run the 7.4.1 installer on all Macs. If you are just using the client on a Mac then press the config/options button in the installer and deselect everything but the client.
Wed Feb 12, 2020 10:37 am
P15-D24 offline
That worked, thank you!
Wed Feb 12, 2020 8:50 pm
gsbrewer offline
Im not sure what im missing, but after installing 7.4.1, and rebooting, indigo is not responding to my switching dark mode on and off. Is there a setting I need to apply in indigo itself? MacOS 10.15.3
Thu Feb 13, 2020 10:02 am
Choose the Indigo 7->About Indigo menu item. What versions does it show you are running for the client and server?
Thu Feb 13, 2020 10:19 am
gsbrewer offline
7.4.1 / 7.4.1
Thu Feb 13, 2020 11:08 am
I'm not sure why it isn't working. It should switch to the Dark Mode appearance immediately upon changing the system setting. I know there are some 3rd party apps that let you disable/enable Dark Mode for specific apps as well as some command line techniques to change the settings. Have ever done either of those?
Thu Feb 13, 2020 12:26 pm
gsbrewer offline
I don't think I have any 3rd party app like that installed. It was a clean install when I installed Catalina. I'll double check.. Any debugging commands or terminal commands you can recommend to help diagnose, let me know I would be happy to help.
Thu Feb 13, 2020 12:30 pm
Can you describe in detail (or take a screen shot) of what you are seeing? Are all of your other apps and macOS windows in Dark Mode and Indigo's are not at all? Is there any difference in Indigo's UI when toggling Dark Mode ON and OFF?
Thu Feb 13, 2020 12:33 pm
gsbrewer offline
Matt, You're proving to be a genius once again :-) ... Yes, somehow, I had nightOwl installed and it was set to leave all apps in light mode. Thank you for your help. Great product!
