UI is very slow.
Sat Feb 08, 2020 7:13 pm
shapa offline
UI is very slow.
For some reason, the client UI is painfully slow even on the recent macs. Many years - the same issue.
7.4.1 improved significantly, but not enough. Multiple computers (including latest macs) - it's not about the CPU / memory. Some old UI API calls used?
Sat Feb 08, 2020 7:21 pm
Re: UI is very slow.
Haven't noticed that. What are you doing in the UI when it seems slow?
Sat Feb 08, 2020 8:33 pm
If you have eg all devices listed and a lot of updates then that can happen.
Sun Feb 09, 2020 5:59 pm
As Karl said, if you have a lot of variable values or device states updating frequently the UI can get slow. Do you have plugins or scripts that might be updating the UI frequently?
